I can buy a new Techsew 2700, Juki 441S, or Toro 3000 branded an Artisan machine for virtually the same money. What would you buy if your primary use was smaller leather accs such as belts, bags, purses etc. I rarely sew over 2 pieces of 8-9oz, but always sew down to 3-4 oz with a mission grain or kid lining. I'm afraid the Juki and Toro may be more machine than I need, but would sure be nice to have if they will do the same job without marking up my projects.
Since I was too late to order from Ron today at Techsew I have the weekend to decide. Any and all help would be greatly appreciated.
Old Guy that can't see too well anymore.
  • Replies 41
  • Created
  • Last Reply
Top Posters In This Topic
Yer puttin me on the spot Pilgrim.
Okay.
I have been there and done that. I tried working my way up to the best sewing machine for the money and blew a small fortune doing so. Here is my advice: Buy the best machine you can afford, even if you have to lease it.
You left out one of the best currently available 441 clones on the market: The cowboy brand CB3500, 4500 and 5500. The 3500 has a 9" arm, like the Artisan 3000, but is made at the best quality factory in China.I own the next model up: the CB4500. I use this machine every day to sew everything from jeans cuffs. to handles on purses, to zippers, to belts, to holsters, etc. I used it today to sew across the back of a shoe where the material had come loose on the inside. There is little this machine cannot handle.
If you aren't interested in the Cowboy brand machines for some reason, the Techsew 2700 would be a good starters' machine. It is a light duty, walking foot sewing machine. While it may be technically able to handle #207 thread, it won't be pretty. The pressure required to hold down the leather may be more than the pressure spring can apply.
In contrast, my CB4500 can sew from 6 ounces up, depending on what size thread and needle I use. With a #19 needle, it sews thin garment leather or jeans, with #92 thread. Plop in a #22 or #23 needle and it sews with #138 thread. Move up to a #24 and it sews #207. Ramp it up a notch to a #25 and it sews #277 thread, top and bottom. This is not the end of the line either. It can sew with #415 thread, using a #27 needle! Did I mention is can sew as long as 2 or 3 stitches per inch? This is with either the smooth feed dog, or no feed dog at all. I prefer no feed dog for my work. Some like it the other way.
If you are going to only sew thin or soft leather, a 227 type machine is adequate. But, once you start playing with the big dogs, a real leather stitcher is needed. That is a 441 clone, or an Adler 205-374, Union Lockstitch, or Campbell-Randall.
Edited by Wizcrafts
Posted IMHO, by Wiz
Hi, what Wiz forget to mention is that the Juki TSC 441, who is one of your alternatives; is the mother of all these clones machine.
Cobra 4, Cowboy 4500, Toro 3000 (shorter arm) and Techsew 5100 are all Chinese copies of this machine. They have a 5 mm higher lift (not the Toro 3000) and leather set up; smooth feet`s and feed dog. Some have also a special needle plate. However, these attachment can be bought from one of our dealers for 2 to 300 $ and installed on the original machine.
The Juki is made in Japan and is a more expensive and better machine. However, if you are going to sew thin leather with threads lighter than Tex 138 a machine like the Cowboy 2500 or Techsew 2700 will do a better job.
The 441 has a very long needle who will easily bend or break in small sizes, it is made for heavy work.
Tor
Tor
Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
One other alternative is the Luberto's Classic which uses 2 needle systems, 794 and 328. I have sewn from 2 layers of 3oz to a full inch on mine. It will sew using a touch lighter thread than the 441 type machines but be sitting down when you price a new one. I have bought several machine from Steve at Leather machine Co and have been extremely satisified with the quality of his products and the service has been outstanding. I have bought parts and supplies from Toledo Sewing and have had good service from them. Shipping between me and Steve is quite a bit less than it is with Bob at Toledo Sewing machine CO. I have never dealt with Ron but I know he has an excellent reputation and that is not easy to get these days. I would not hesitate to buy from any of the above. Do yourself a favor and stay with a reputable dealer. HTH Ken
The Techsew 2700 is a good machine for light and medium duty leather sewing. It has a 10.5 inch cylinder arm. It will sew from 1/32 inch (2 oz), with #46 thread, up to 3/8 inch (20 oz), with #138 thread, top and bottom. It can handle #207 thread on top and #138 on the bottom. Needles are readily available from tiny sizes, like #10 or 12, all the way up to #25, in leather points of various geometries. There are dozens of miscellaneous presser feet that fit the machine. Help is a phone call away, during business hours, from Ronny, at Techsew.
I can't imagine where you were going to buy a Juki 441 for the same price as a Techsew 2700. The Juki TSC-441 typically lists for over $5000. If you bought one at half price it would be in the vicinity of $2500. I believe that in stock configuration, the TSC-441 has a 12 inch arm, but I might be mistaken.
The Toro 3000 is a 9 inch cylinder arm, heavy leather stitcher. It is best used with thread sizes starting with #138 and going up. It should be able to sew into about 4 to 6 ounces of leather, or up to 7/8 inch. It uses system 7x3 regular point, or 794 leather point needles. I think they sell for $2,000, or so.
Posted IMHO, by Wiz
A TSC 441 for that price will be a good buy, even if you had to change some parts on it. The TSC 441 only comes with a 16,53 inches arm. It is a long arm version called TSC 461 with a 37 inches arm. The Juki 441 costs 5750 $ head only where I live, I believe thats about the same as the global price, there are no tax on sewing machines here.
Tor
The Juki 441S is a lightly used machine from a reputable dealer that also happens to sell on ebay. I have been negotiating with him for a couple days and have managed to get a lower price on his items. I will show you his listings, but please, nobody scoot up under me on these until I decide. :-)
http://www.ebay.com/itm/220676926994?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.com/itm/Juki-441S-/221075919956?pt=BI_Sewing_Machines&hash=item337926d454
And then this one from Ron:
http://www.ebay.com/itm/150967761918?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Do yourself a favor, stay away from ebay!!!!
Call Steve or Toledo Bob, they all have these machines tested and sewn off...yes maybe you save 200 bucks, but down the road when the ebay dude long forgot your name....these dealers on here will help you in any way they can!
Jimbob
http://www.elfwood.com/~alien883
First it is just leather....then it is what-ever I can dream off...
I'm afraid I agree with Jimbob. Work with one of the dealers here. They will take good care of you and may even be willing to meet the price of the ebay guy.
One thing I wanted to mention. The sewing I had done prior to having my Toro3000 was always on a flatbed industrial or a home flatbed or one that converted from flat to free arm. A cylinder arm machine is a whole different critter and take some time to get used to. First these machines are HUGE and intimidating and have the power to sew through flesh and bone and keep on going. (scary) for that reason I would recommend that if you have never sewn before to get with someone who is willing to spend time with you and allow you to get the feel for one of these machines.
A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
