Contributing Member SooperJake Posted January 11, 2013 Contributing Member Report Posted January 11, 2013 (edited) I worked on a gun belt today stitching with the Cowboy CB4500. I had a number of spots where the stitch was either shorter than the setting or much longer than. Is it me and the feed pressure I am applying ? Can a sewing machine do this all on its own? Please suggest corrections if you can. Pictures tell all. Thanks Edited January 11, 2013 by SooperJake Quote Once you know what the magician know.... it isn't magic anymore.
Members tnawrot2 Posted January 12, 2013 Members Report Posted January 12, 2013 Try sewing a piece of leather the same thickness without forcing it, just hold your fingers on each side to guide it. I believe the Cowboy cb4500 is a compound triple feed machine, and you shouldn't try forcing the material, the needle will feed the material at its own pace keeping the stitch length equal. Quote
Moderator Wizcrafts Posted January 12, 2013 Moderator Report Posted January 12, 2013 Are you just using the minimum pressure needed on the presser foot? If so, the stitch length can be changed by the weight of the belt as it folds over the arm, or by your hand pressure as you guide it. When I notice variances in stitch length, I tighten the pressure screw and support the strap for a few inches behind the head, with my left hand. This is where the table attachment can help you out. It keeps the belt or strap flat, removing gravity from the equation. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Contributing Member SooperJake Posted January 12, 2013 Author Contributing Member Report Posted January 12, 2013 (edited) Are you just using the minimum pressure needed on the presser foot? If so, the stitch length can be changed by the weight of the belt as it folds over the arm, or by your hand pressure as you guide it. When I notice variances in stitch length, I tighten the pressure screw and support the strap for a few inches behind the head, with my left hand. This is where the table attachment can help you out. It keeps the belt or strap flat, removing gravity from the equation. Wiz, I do have the foot pressure turned down to the bare minimum. I haven't used the table yet and was told that would also help, in conjunction with the roller guide. Is that so? I still have the standard plate on, and I went back to the standard double foot. I was pretty sure the problem is me and not the machine. On smaller stuff like holsters and my test and practice pieces it has worked flawlessly. Edited January 12, 2013 by SooperJake Quote Once you know what the magician know.... it isn't magic anymore.
Moderator immiketoo Posted January 12, 2013 Moderator Report Posted January 12, 2013 Wow Jake, I had NO idea the machines could be so tricky. That's a sizable difference between stitches! I can't wait til I get one, then I will be able to feel the pain! Let us know how you get it sorted. Quote Learnleather.com
