Supplier For (Solid) Brass Or Antique Finish Snaps?
Hi, I was wondering if anyone knew a place for some quality snaps that are solid brass or antiqued brass plated, maybe around line 20-24? Most of the brass finish hardware I've used doesn't seem to last and feels kind of tacky...
I've looked around and developed a quite a paranoia about ordering some crappy stuff. Hoping someone might know of a quality supplier?
Thanks for all the help.
Have you tried DOT? Those should be good ones, just search durable dot or Scovil, you can order straight from the manufacturer, $50 minimum, they would probably send you samples too. They have Brass, nickel plated brass, government black and stainless steel. I'm awaiting my order currently, I'll report back but I'm sure they're the good ones.
I got some solid brass ones from ZW, but they seem really thin and didn't set well posts folded and crushed.
Jeremy
  • 2 weeks later...
Try Sav Mor out here in Los Angeles. They have antique brass, antique silver(!), and brushed silver snaps. Good guys too!
http://savmorleather.com/
Andy
Try Ohio Travel Bag. Good products, great service and large selection.
Ray
You can either here - http://www.ebay.com/itm/181063569040?_trksid=p5197.c0.m619
or - http://www.ebay.com/itm/221037237718?var=520091467404&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I received test pack of 10 from second one. They are pretty good antique. Picture doesn't show real look up, but is good enough.
