Members Csr111 Posted March 6, 2013 Members Report Posted March 6, 2013 Hey Everyone - So I'm buying a used Juki LU - 563, my first industrial machine, so I'm going to need to buy everything else besides the machine itself. I will be making wallets like those in the pictures below, which will consist of a several layers of thinned leather and lining. I've been using an old singer that I've made work (not very well) for my needs, but I'm not happy with the quilty of the work, which is why I am switching to the proper machine. I'd greatly appreciate anyones input on what you think I should buy and would be the best for my needs: table, motor, needles, thread (if i need different size thread on top vs bottom), sewing guide for straight stitching, etc... Also let me know where I can buy thinks that you recommend. Also please include any other tips / advice because I really want to make sure i do this right the first time. Thanks! Casey Quote
Contributing Member Ferg Posted March 6, 2013 Contributing Member Report Posted March 6, 2013 Nice work on your wallets. I cannot help you much on the Juki, if I remember correctly the accessories are expensive. Wiz will probably have some answers for you. ferg Quote
Moderator Wizcrafts Posted March 6, 2013 Moderator Report Posted March 6, 2013 (edited) The LU-563 goes back to the mid-1980s. It has a double capacity hook and bobbins and compound feed, with a reverse lever. I had one in my previous life and found it adequate for wallets, vests and belt edges. Are you just buying the head, or is it complete, on a table? If it's just the head, you are in for some sticker shock as you gear up to use it. Here is what you need to use this machine: Machine head, with proper hinges for table mounts Steel legs table, with proper cutout and rubber mounts for machine base, plus, holes for a flex light, motor, fold back peg, a belt slot, and a parts drawer Motor and switch box, with power cables and cable clamps.. V-belt of proper length to go from motor pulley to machine flywheel and be within adjuster range on motor. Bobbin winder assembly Thread stand assembly Oil pan to fit machine and table cutout Knee lever assembly for this type of machine Flex lamp If all of the above come with your Juki and you are buying it for no more than about $500 to $600, you are doing okay. Otherwise, expect to pay $250 to $400 more to get the table, motor and other aforementioned parts needed to finish it off. Edited March 6, 2013 by Wizcrafts Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Csr111 Posted March 7, 2013 Author Members Report Posted March 7, 2013 Thanks, Wiz - I have no idea what specifically to buy or where to buy it. Would you be able to help give me some more detailed info? I am only purchasing the machine head, so i'll need everything else. Ideally i'll want to run at a slower spead (servo motor). I figured I would have to drop some $$$ to get it setup the right way. I really apprecaite the guidence. Thanks, Casey Quote
Moderator Wizcrafts Posted March 7, 2013 Moderator Report Posted March 7, 2013 My advice to you is to buy a complete walking foot machine, already equipped with a good servo motor, setup and tested on leather. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Moderator Art Posted March 7, 2013 Moderator Report Posted March 7, 2013 Casey, We need to know where you are located to give you advice on dealers. At the top of the page, you will find several machine dealers that can set your machine up for leather. Hopefully, you haven't bought just the head. Call Steve at Cobra or Bob at Toledo or Ron if you are in Canada, and see what they can provide. They can each provide a setup for leather. Don't try to shop it for price, they will put it all together for you and it will work from the start. Art Quote For heaven's sakes pilgrim, make yourself a strop!
Members Csr111 Posted March 8, 2013 Author Members Report Posted March 8, 2013 Unfortunately I don't have the budget to purchase like you recommend WIZ, but thanks for taking the time to help out. Art - I am located in Richmond VA. I've not found many dealers, even in the DC area which was suprising to me. Let me know if you have any info that would be helpful. Casey Quote
Members pcox Posted March 8, 2013 Members Report Posted March 8, 2013 Buying a machine without all the stuff on the list is like buying a car without tires, wheels and a battery. You just can't use it without the complete pakage. Quote
Moderator Wizcrafts Posted March 8, 2013 Moderator Report Posted March 8, 2013 I once saw a walking foot head on eBay, where the seller had mounted a home sewing machine motor and small ribbed belt to the back and used it to drive the machine, via a foot speed control. The machine itself sat in a custom made box. This was an example of a 60 pound portable walking foot machine. Maybe you can build a box to hold it and mount a 1.5 amp motor to the back to drive it? Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members pcox Posted March 8, 2013 Members Report Posted March 8, 2013 If you are a good scrounger you might build a table, put a screweye in the ceiling above the machine instead of a thread stand. you will need a bobbin winder (less than $10 new). We run a singer 331k1 with a 1.5 amp motor like Wiz said but its's on a quilting machine not much punching power.and it's pretty fast. thread is about $18 for a 1 lb cone you really need 2 , 1 for the machine 1 for the bobbin winder. Running the bobbin winder with a motor on the machine will be another problem. You may find a used clutch motor that someone else has taken off and put on a servo motor not the best choice but it will work ok and might be a lot cheaper. Quote
Members Anne Bonnys Locker Posted March 9, 2013 Members Report Posted March 9, 2013 I have seen 240V domestic motors rated to 250W but not sure what life expectancy would be like. These are ok for some things but probably wishing a bit to sew anything hard. At the moment I am building a Singer 19-10 feed up the arm zig-zag machine to sew stubby holders and the supercharged domestic motor will work well. Quote Darren Brosowski
