Anyone have any ideas on a Mares Leg holster that sets on your back? I'm thinking of running a strap with snaps that can be attached to a buckle that's mounted to the holster, Basically make a strap that goes from over the shoulder to the waist with an attachment that will connect to the belt to help secure the holster when you draw the weapon. Any other ideas would be great.
I've only made one, . . . had a ball with it too, . . . and if I had your customer, . . . I'd make him/her one like this one.
Add to it a shoulder strap that goes up and over the shoulder, . . . down and around the chest and comes to the other end of the holster in the back.
If you do this, . . . you make a left hand holster for a right handed person (opposite of the one I have in the picture), . . . so he can pull it out and it will be properly oriented for use.
You make that strap so that it has a slot in it like a buscadero loop on a western holster.
You will also have to make a template for the shoulder strap, . . . for it to be comfortable, . . . there will have to be a serious crook in it up at the shoulder end, . . . a straight 3 inch or 2 inch strap will dig into the shoulder really hard.
Good luck.
May God bless,
Dwight
post-6728-0-74955600-1363130632_thumb.jp
Edited by Dwight
If you do a search there is a similar rig some one made for a shotgun, I think he inleded a bandolier with it. If I find it i will post the link.
Found it hope it helps
http://leatherworker.net/forum/index.php?showtopic=42447&hl=%2Bshotgun+%2Bbandolier
Edited by camano ridge
Thanks for the help there fellas.
