pricey!!!
Emergency Room Nurse by profession.......Leatherworker at heart!!
Hoping to reverse the order in that one of these days!!
They are pricey lol, prices for a new Blanchard pricking iron with 10 teeth alone can set you back over $200. I purchased these only a few months ago. I find I use a No. 10 more in my work.
Are these for marking or punching?
These will mark or punch holes, one of the forum members, Sean, did a good write up on Blanchard pricking irons on his blog. And below are a few youtube videos.
Skip to :20 sec
http://www.youtube.com/watch?v=75Q-_AaNhbk
Sean's blog
http://www.fineleatherworking.com/blog/using-pricking-irons/
Jnk Using a pricking iron (not sure if his is Blanchard), skip to 1:20
Thanks for those links, particularly the last one.
... I just purchased a couple of #7 Dixon (1 1/2" and 1/2") pricking irons. Do you know how the tooth size compares? I would really like to have a 2 tooth iron.
Each blade width is roughly 2mm wide, and from blade to blade is roughly 3mm diagonally, hope this helps
Thanks for taking the time to answer, Lee05. Please advise if you decide to split the set. I am very intersted in the two tooth iron.
Where can I buy different sizes of the Blanchard pricking irons?
