Members kayrunp Posted April 16, 2013 Members Report Posted April 16, 2013 I bought 7in end nippers from Home Depot for the task of cutting the copper rivets. My small hands just can't get it done with this tool. I figure its a crap tool and I don't have the power. What tool do I need? Thanks! Quote
dirtclod Posted April 16, 2013 Report Posted April 16, 2013 The tool you have is what i have always used. If it's where can put the end of one handle on your bench and squeeze that will give you more power or you may find some with a longer handle and that would be easier for you i think. If you go looking again take a rivet with you and see if you can cut it before you buy. Quote
Moderator bruce johnson Posted April 16, 2013 Moderator Report Posted April 16, 2013 I use compound action end nippers. The ac tion makes them cut much easier. Osborne makes a decent enough smaller one but if you hunt old antigue stores look for a pair of Schollhorn-Bernard compound action end cutting nippers. I buy them for $5-10 when I see them. Rarely are they worn much. Quote
Members kayrunp Posted April 16, 2013 Author Members Report Posted April 16, 2013 Thanks Bruce and dirt clod! I found a pair of compound action end nippers on eBay and bought them, hopefully this will help me out. Quote
Members Dwight Posted April 16, 2013 Members Report Posted April 16, 2013 (edited) It'll cost you a 20 maybe more, . . . but a good pair of Klein lineman's pliers will chop them babies right now. I used to do electrical work, . . . kept the tools, . . . you don't need to guess what I use. You also may be using them wrong, . . . you need to get that rivet down as far into the cutting slot as you can. Your max pressure is down there. The "ideal" tool is a pair of angled side cutters, . . . also made by Klein, . . . but unlike the pliers, you would only use them for rivets, . . . the pliers would have a few other uses, . . . side cutters, not so. May God bless, Dwight Edited April 16, 2013 by Dwight Quote
Members Hillbilly tim Posted April 17, 2013 Members Report Posted April 17, 2013 +1 on the Klein lineman pliers Bro Tim Quote
Members kayrunp Posted April 22, 2013 Author Members Report Posted April 22, 2013 Hi Bruce, Did I get the wrong tool? It's too narrow of an opening for the rivet. Hi Bruce, Did I get the wrong tool? It's too narrow of an opening for the rivet. Quote
Moderator bruce johnson Posted April 22, 2013 Moderator Report Posted April 22, 2013 It looks like the right tool, just the wrong size if the jaws won't open enough the get the shank of the rivet between them. Quote
Members kayrunp Posted April 22, 2013 Author Members Report Posted April 22, 2013 it was the 6 inch pair. Quote
Trox Posted April 24, 2013 Report Posted April 24, 2013 Hi Bruce, Did I get the wrong tool? It's too narrow of an opening for the rivet. Hi Bruce, Did I get the wrong tool? It's too narrow of an opening for the rivet. Hi, take the pliers apart and remove some of their edges on the grind stone so it gets a bigger bite. (It looks like it possible to take apart). Be careful and keep it cool so it does not get blue and loose its tempered. Tor Quote
Members tnawrot2 Posted April 24, 2013 Members Report Posted April 24, 2013 I use cheap 16" hoof nippers, they are about $14.00 at Harbor Freight, Jeffers or kv supply. Quote
Members kayrunp Posted April 26, 2013 Author Members Report Posted April 26, 2013 I ended up getting some greenlee diagonal cutting pliers. My wee hands seem to be able to mange these and they are sharp and appear well made. Now onto getting a nice dome on these rivets. Thanks for your help! Quote
