Northmount Posted April 28, 2013 Report Posted April 28, 2013 I was watching the video Nothmount put up again and noticed something about the pattern. The brim size would be 4 inches in the front and back but the sides would only be 2 3/4 on each side? Is that normal for a hat to have a smaller brim on the sides then the front and back? John I'd use the pattern from bushcraft just above your last post. It looks better and gets rid of the seam down the front. I just took a look at the corrected pattern near the end of the video. The brim is the same width all around. See the frame grabbed here Tom Quote
Members johnggrg Posted April 30, 2013 Author Members Report Posted April 30, 2013 Well I am not good at making my own patterns and the one video is in cm. So I think what I am going to do is use the Tandy mavrick pattern;s brim and use the altered crown and top from the bush hat. That one is my size anyway. So the two should go together. I guess no one here has ever made the Mavrick hat before. I figured someone would show a picture of one they made. Oh well. Thanks anyway. John Quote
Members Madadh Posted April 30, 2013 Members Report Posted April 30, 2013 I made a very simple bush hat using the following steps. 1. Measure your head and on a large cardbord cut a cirlce the size of your head. 2. Cut a second circle 3.5 to 4 inches arround your first circle. 3. Cut a 4 inch wide strip 2 inches longer than your head size. 4. Sew together -- I didn't skive the sides and it worked well for me. I sewed the crown part inside out like the video above and then sew to the brim. The last thing I sew is the strip ends in the back of the hat. With it being 2" larger than your head size just cut it to make it fit. 5. Dye hat to desired color 6. Finish using a good water sealant. Hope that helps. Quote Sláinte Rob bainne na mbo dos na gamhna, ach sú an eorna dom fhéin Milk of the cow is alright for the calf, but the juice of the barley for me
Members johnggrg Posted April 30, 2013 Author Members Report Posted April 30, 2013 Thank you for the reply Madadh. For the brim I was going to use the brim from the Tandy Maverick style hat. The pattern was free over on the patterns and templates section. It has premarked sizes in it. An then I will go from there. John Quote
