Members Tannin Posted August 1, 2014 Members Report Posted August 1, 2014 (edited) Nail polish remover used to be carbon tetrachloride - which was also used for dry cleaning - it is carcinogenic (can cause cancer). Things may have changed but I'd avoid sniffing that stuff. I expect isopropyl alcohol, rubbing alcohol or - in the UK - methylated spirits ("meths") would work, they are all organic solvents. Yes, alcohol tends to harden cells, so I'm not surprised that it might harden leather - perhaps that is also why it is so bad for the liver? A Botanist told me they use it to harden plant cells when preparing them to go on microscope slides. BTW If you search the forum for "oxalic acid", there is a discussion on using this acid before dying leather. Coincidentally I just received some in the post today but I will use it to remove tannin stains from an oak bowl rather than on leather (it is often sold as "wood bleacher" & sometimes as "alloy wheel cleaner"). It is corrosive & poisonous, so gloves & safety glasses would be prudent. White vinegar might be a safer (but weaker) alternative - I use a white vinegar spray as a general cleaner - "old school". Yes, washing hands frequently with soapy water is a good idea - learnt that the hard way handling newly finished bowls . Edited August 1, 2014 by Tannin Quote Simple Leathercrafting
Members jfdavis58 Posted August 1, 2014 Members Report Posted August 1, 2014 Fiebing's Deglazer is 70-90% Ethyl acetate the remainder being ethyl alcohol. Ethyl acetate vaporizes rapidly; so much so that after a few months storage in a 'tightly stoppered' container only a small amount may remain in the can-it of course being mostly the alcohol remnants. Only Fiebings seems to know the mechanism by which the deglazer works. I suspect that it 'denatures' and dissolves oils from the fingers, dissipating and drying the remaining materials into and off of the leather mostly as a dead dry dust. I keep a can just in case but find that with normal hand washing and careful handling it is rarely needed. The one or two times I thought I needed it, it didn't seem to do much by way of removal (that a clean dry cloth could have readily accomplished with one or two swipes) and I got a strong headache from the fumes. The leather surface did become harder, subsequently the dye absorbed faster. If my hands feel anything other than dry I wash them with a simple bar soap or on occasion use a pump delivered hand sanitizer (mostly an alcohol substance). Denatured alcohol is adulterated--contaminated by a non-human friendly liquid to make drinking it unpalatable and dangerous. Gasoline is one such additive; benzene and similar aromatic hydrocarbons are also used. Unless you buy your ethanol from a drug/chemical supplier (with appropriate license) as pharm grade or get it as grain alcohol from a liquor dispenser (Everclear and expensively taxed) you ALWAYS GET denatured alcohol in the USA. Ethanol a heavily regulated and taxed commodity! Carbon-tetrachloride is know (by more than just the state of California) to be carcinogenic, toxic and generally harmful to most living things. It's tightly controlled and heavily regulated-not easily obtained by the general public. It's principle use in times gone by was to clean ribbon based typewriters of accumulated ink residue, paper dust and other materials referred to as crud, junk or ***** (deleted for social reasons). Logically it was and may still be used in the newspaper and printing trades especially if the still employ older metal based offset production. Fingernail polish and fingernail polish remover are usually (partially or wholly) adulterated acetone(by perfume and softening agents as well as the color ingredients). Acetone can be found in the paint aisle of most home improvement centers and requires nothing more than common sense in storage and handling. Vinegar is acetic acid in water, diluted heavily. As acids go it wouldn't be very strong anywhere outside a lab or industrial situation; even then it's seldom above about 35%. The white version more filtered than the red/tan to brown looking varieties. All of these substances work against the very things most prized in leather: it's suppleness, resiliency and resistance to other contaminations. Several can in fact contaminate leather to the degree that it must be discarded. Except for vinegar all have adverse effect on humans and require some care in handling. Quote
Northmount Posted August 2, 2014 Report Posted August 2, 2014 Nail polish remover is now acetone. If you use much, it's cheaper to buy at paint and hardware stores. Also used to cleanup tools after using fibreglass resin. So is also available at automotive and boat shops/stores. EPA doesn't and California haven't classed acetone as a smog producing volatile organic compound, so it is being used in paints and finishes now. That doesn't mean it's not a harsh chemical. Don't breathe too much of it! Tom Quote
Members Robski Posted March 6 Members Report Posted March 6 Hi, I realise I'm reopening an old thread...! But only as it seems relevant. I have a new, clean, unworn pair of heavy leather motorcycle boots I plan to dye, so no dirt - just an undamaged tough looking smooth surface. I have some dye but don't have any deglazer or preparer available locally; is it necessary? Comments re pre-dyeing leather prep seem to always refer to old shoes - that they will be scuffed, dirty & have had various polishes on them to remove, which obv. doesn't apply to new. I believe some leather footwear can have an acrylic coating, is this most footwear or are there other coatings commonly used? Basically, can I get away without using any chemical pre-treatment? I looked up the Fiebings Preparer safety data sheet; it is described as ammonium hydroxide 27% & 2-propanol (aka. isopropyl alcohol). The ammonium is a strong alkaline substance but is presumably diluted somewhat with the alcohol. Their Deglazer, as has been said previously is ethyl acetate which is chemically close to acetic acid (?) So I wondered if the e. acetate is milder or stronger in effect than the vinegar? I also read that use of acetone (a neutral substance -which I have) on leather seems to be a no-no - it's too harsh & can apparently damage the leather permanently (?) I do have some very strong (77%) acetic acid, (white vinegar) - obv. very acid compared to common white vinegar. Would this work to prep / deglaze? Perhaps mixed with water? I'm interested in the process, just don't want to experiment & ruin my boots! Quote
Contributing Member fredk Posted March 6 Contributing Member Report Posted March 6 I rarely use a deglazer. But I often redye leather. As a pre-dye prep I'd use some cellulose thinners. On a rag, wiped over the boots a couple of times Quote Al speling misteaks aer all mi own werk..
Northmount Posted March 7 Report Posted March 7 Moved this thread to Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners. Quote
Members Robski Posted March 8 Members Report Posted March 8 On 3/6/2025 at 9:13 PM, fredk said: I rarely use a deglazer. But I often redye leather. As a pre-dye prep I'd use some cellulose thinners. On a rag, wiped over the boots a couple of times Thanks for that tip. Much appreciated. I usually have various chemicals in the workshop for paint & varnish. Funnily enough after posting I bought some basic "acetone free" nail polish remover containing Ethyl Acetate. Since they usually contain various additives to be be more gentle on the nails, I discovered that you can fairly easily distil the EA from the overall mixture using a salt solution. The cheaper own brand remover actually is easier since it has fewer additives. The EA fumes are very pungent & not good to breathe, so it should be done outside, or with a good ventilation / extraction system, with sensible precautions; chemical resistant gloves & goggles. The same care as no doubt recommended on the Fiebings bottles. Quote
