Moderator Wizcrafts Posted June 15, 2013 Moderator Report Posted June 15, 2013 Oil is not thread lube. The best I have found is from Puritan, Ceroxylon wax. Lubes the thread great then dries &sets and seals the stitches.I first thought $65 a gallon was high but after useing it worth it to me. don't gum things up. Which machines do you use Ceroxylon with? Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members pcox Posted June 15, 2013 Members Report Posted June 15, 2013 (edited) Wiz I use it in the puritan high speed , singer 29 patcher, and when we make bio harness the Landis# 1 and cb4500. I think it really helps the thread pull up in the bio, takes less tension to set the stitch. I think it would be great in the 45x25. I like the purtian setup where the wax pot is after the tenison disk Edited June 15, 2013 by pcox Quote
Moderator Wizcrafts Posted June 15, 2013 Moderator Report Posted June 15, 2013 Wiz I use it in the puritan high speed , singer 29 patcher, and when we make bio harness the Landis# 1 and cb4500. I think it really helps the thread pull up in the bio, takes less tension to set the stitch. I think it would be great in the 45x25. I like the purtian setup where the wax pot is after the tenison disk Does Ceroxylon gum up the tensioners, guides, or needle's eye? Is it water soluble if it thickens in the pot? Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members pcox Posted June 15, 2013 Members Report Posted June 15, 2013 I have not had any of those problems with it. It will dry on the thread down the thread path from the pot if it sets over night making the thread stiff. I just pull that thread out of the needle till I get fresh lube to the needle. I have not had it thicken in the pot yet so I haven't tried to thin it but I think it is water soluble as it washes off my hands easily with plain water. there # 1-860-693-0791 or puritan.industries@snet.net Quote
Members Anne Bonnys Locker Posted June 19, 2013 Members Report Posted June 19, 2013 A couple of 45's I've played with have a small problem with the tension assembly. Keep in mind that the 45k tension is completely different to most other machines in that the thread is wrapped around the tension wheel which spins to feed the thread and the tension spring retards the motion of the wheel. Pull the tension apart, polish all of the mating surfaces with ultra fine steel wool and then apply a light coat of oil before reassembling. Quote Darren Brosowski
