avimeso
Plain Western Bridle
You have the needed dimensions... Now just get creative (with posterboard first) your imagination is all you need now. Look around and take inspiration from other headstalls you like. Inspiration is just a fancy word for theivery. ;)
Rufus
As Rufus said, it's up to you to use your imagination. However, what are your dimensions on the different components? Your browband appears too large compared to the other parts of the bridle.
If you burnish and rub the edges of the straps, you would have a more attractive piece. Also, lining your work will give you a stronger piece of tack, and a more attractive look. If you don't want to line your straps, you could also apply Fiebing's Leather Balm to the flesh side of the straps so they don't absorb swet.
Ron
I found there were too many different measurements on the market so I've designed all my tack to fit my 15hh qh who I consider pretty average. This was a test bridle I put oil on it and it came up alot more finished.
My strap cut out sizes are.
Brow is 28
Points are 32
Buckle strap 15
Throat is 47
This is suppose to be harness leather however if I was going to line id use bridle leather.
I'd like a pattern for a 1 eared bridle if anyone can help as I don't own one to copy
