Members najram2007 Posted July 20, 2013 Author Members Report Posted July 20, 2013 Thanks for all the advice guys. I put an order in for a Cobra class 4 from the only Australian supplier, Queensland sewing machines. The owner Greg is awesome and so helpful! Cant wait to get it. Should be next month some time. Andrew,, It is a leather liner. The bag in the picture isn't my make, Its a bag a picked up at a second hand store. Tor, how do you reduce the height of your stirrup plate? Thanks, Marj Quote
Members Andrew Chee Posted July 20, 2013 Members Report Posted July 20, 2013 You don't need to reduce the height if the stirrup plate. It will work just fine as is. Make sure you use a right toe presser foot Ecuador that's what the plate was designed for. You have to lengthen the stitch length because the stirrup plate requires that you remove the feed dog and that reduces the contact on the leather thereby reducing the stitch length which has to be compensate by increasing the stitch length. Also be more careful when you go around the bend because the stitches tend to bunch up a bit around these tricky areas. Not a big deal, just something to watch out for. Andrew Quote
Trox Posted July 20, 2013 Report Posted July 20, 2013 (edited) Thanks for all the advice guys. I put an order in for a Cobra class 4 from the only Australian supplier, Queensland sewing machines. The owner Greg is awesome and so helpful! Cant wait to get it. Should be next month some time. Andrew,, It is a leather liner. The bag in the picture isn't my make, Its a bag a picked up at a second hand store. Tor, how do you reduce the height of your stirrup plate? Thanks, Marj Hi Marj, I bought the plate I am talking about from Cowboy, it was to height for my use (for several other members too). I reduced the height with my bench grinder, slack belt grinder and Dremel tool (made a small flat foot support on the top of it, sorry no pic`s). Made sure it kept cool all the time not to mess with the tempering. Finally, I cleaned it up with a Dremel and gave it a good polish on the buffing wheel, pretty much like I modify any other sewing attachment that needs it. There are different stirrup/ bag plates out there; this is maybe the highest of them. It steals capacity from the foot lift and its curved form makes a bad support for the sewing feet. The perfect stirrup/ bag plate would also allow use of the feed dog underneath as a needle guide. (It’s a big job to change to this plate from a regular one) A member friend designed and sent me a 3D printed stirrup plate that is about perfect. It’s a bit high because of the material in use (it’s a plastic compound and needs to be thick), it works very well). The CB stirrup plate also have a too narrow feet (sewing) support, when you use the double harness foot the right toe has no support; It hits outside the plate. The foot is 12 mm and the support on the plate is only 8 mm wide. I do not have a right toe harness foot yet (in order), but others report it hits outside the plate (of course it does; it has the same position as the right toe of the double foot). This is clearly a manufacturer error, these attachments are all from the same brand (and plate is made for use with this feet’s). There have been allot of discussion about the difference in material between clone brands accessories, the fact is they all look the same. My guess is they all are too, that’s how things works in China, one factory one part (more or less of course) We spend allot of time telling others about how great our equipment are, it is important we post about the faults too. Or else we cannot expect any development and better tools. When we talk about thread tension and if you have to adjust or not using this plate; it is of course depended of the conditions and the pre change settings. (Some use much tension others less, thread, size, lube or not, feed dog or not etc.) There are differences in threading and tension disk setups too. You can’t compare with out use the same of everything and it’s not important anyway. Most of the accessories for these machine works great and do not need any modification, it somewhat surprising this plate has faults. Tor Edited July 20, 2013 by Trox Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Members Andrew Chee Posted July 21, 2013 Members Report Posted July 21, 2013 This is interesting. The plate I have comes from cobra Steve and was designed to use just with a right toe presser foot. There's no room for the left toe. It's also not designed for use with a feed dog. It is pretty high so the sewing capacity is definitely lessened but I guess you trade capacity for clearance. I'm interested in looking at this 3d printed plate. Can you post a picture of it? Is it durable enough with the constant thumping of the feet? Andrew Quote
Trox Posted July 21, 2013 Report Posted July 21, 2013 This is interesting. The plate I have comes from cobra Steve and was designed to use just with a right toe presser foot. There's no room for the left toe. It's also not designed for use with a feed dog. It is pretty high so the sewing capacity is definitely lessened but I guess you trade capacity for clearance. I'm interested in looking at this 3d printed plate. Can you post a picture of it? Is it durable enough with the constant thumping of the feet? Andrew HI, both Wiz and I have received one each, mine was the second and a improved model. You can use the feed dog under it and it wide enough for the harness foot. I cannot post a picture without asking the member who made it first, because it is possible it going in production. It has an improved construction to make it stronger. Although, its very strong it is best suited as a prototype. I will ask for permission to post a pic of it here later today. Tor Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Members GoldenKnight Posted September 28, 2013 Members Report Posted September 28, 2013 (edited) A few months have passed by. Still no picture. Need a status update when you get a chance, please. This is something that is on my upcoming list of projects as I am narrowing my final thoughts on purchasing a new sewing machine. So ... I'm trying to see which machine and options I need to make sure I get when I order my machine. Edited September 28, 2013 by GoldenKnight Quote No dead ends -- only detours.
MadMorbius Posted October 27, 2013 Report Posted October 27, 2013 I've been sewing round corners on messenger bags on a flat table Juki LU563 for some time. What's the purpose of the stirrup plate in this scenario? Is the idea here that you can pull the excess material out of the way of the feed? Quote
Members CCPhotog Posted January 24, 2014 Members Report Posted January 24, 2014 I just pulled the trigger on a CB3200; will it work for bags like this? Quote
Members Palermo Posted February 5, 2014 Members Report Posted February 5, 2014 Yes the CB3200 will do the job. But stitching round gusset corners takes a lot of skill. The stirrup plate gives a lot of help. I would recommend practice on scrap pieces. The best (meaning easiest) machine for stitching round gussets in my opinion are shoe patchers Quote
Moderator Wizcrafts Posted February 5, 2014 Moderator Report Posted February 5, 2014 Due to its limited lift, the stirrup plate is impractical on the CB3200. The stirrup plate is 1/2 inch tall and the feet can only raise 5/8 inch above the low throat plate. The presser feet need at least 1/8 inch clearance to alternate up and down. Thus, if we subtract 1/2 (4/8) from 5/8 inch, we are left with 1/8 inch - 1/8 inch for foot alternation = zero thickness can be sewn. The amount of alternating foot lift can be varied by moving a crank that protrudes out of the back of the body, up or down in a curved slot on a housing on the back. In practice, one could move the presser foot control lever all the way up, reducing the amount of alternation to maybe 3/32 inches. This would allow you to use the stirrup plate to sew about 1/16 inch of leather, before the mechanism binds. One could buy a Cowboy, Cobra or Techsew stirrup plate and have it ground down to 3/8 inch rise, then reshaped and polished. This would allow the CB3200 to sew into about 8 ounces of leather. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
