I've been reading up on thread sizes and uses etc, along with thread/needle charts. The problem I'm having is that I can't visualize the thread sizes.
Has anyone put together or have run across a picture based explanation? Something like lines of stitches in different thread weights compared to a ruler or a penny or something?
Chuck
  • Replies 22
  • Created
  • Last Reply
Top Posters In This Topic
Here is a thread size vs needle size chart. The diameter of each size thread is listed in the right-most column.
Posted IMHO, by Wiz
Thanks Wiz! I've studied that one. I'm just having trouble picturing sizes.
I guess what I'm saying is that I'm looking for picture comparison of thread sizes, especially against a known object etc to see what looks right for what I need.
Chuck
I understand the question well...it's really a see, touch, feel kind of thing.
Kind of like working with pipe fittings and such; after a while working with them, see, touch, feel, you just know from experience what sizes are what, more or less. Thread can throw you off once in a while, but you just know after a while, more or less.
Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Chuck;
I'll try to give you a better understanding by describing typical uses of the various sizes of thread (in leather work).
First of all, the thread uses in leather sewing machines is usually bonded nylon or polyester. Harness stitchers can also use linen thread that is run through a wax pot. The bonded threads are referred to as numbers, or a letter-number, such as #69 or T70 (equivalents). Linen thread is rated by the number of cords that are twisted together and glazed in place (e.g. 4 cord).
The sewing thread used for leather increases in diameter and strength as its number increases. If we use #69 = 1 (11 pounds test) as the baseline, #92 = 1.5x, #138 = 2x, #207 = 3x, #277 = 4x and #346 = 5x.
The threads uses for hand sewing leather are normally rated by the number of cords that are twisted and waxed together. They seem to average a range of between 4 and 7 cords. Four cords would be about the same diameter as a #207 or 277 bonded thread, but would have much less breaking strength. Linen, cotton, or hemp cord is not typically as strong as nylon or polyester of the same diameter.
A holster that one would hand sew with 6 cord waxed linen thread could be sewn with #277 bonded nylon and be just as strongly secured, per stitch. However, the 6 cord thread would actually be thicker and look more impressive to the eye.
If you are at all familiar with the thread that is used to sew a normal dress shirt, think of it as about the equivalent of a bonded #33 or even a #46. Think about the thread that is used to top stitch your jeans and it will fall around the same thickness as our bonded #69 or bonded #92.
Leather garments are usually sewn with thread sizes ranging from #69 to #138. The #138 is used to hold thicker seams together. It has 22 pounds of test per stitch. Zippers are usually sewn with #69 or #92, so look at the outside zippers on a leather jacket for a reference.
Upholstery shops normally use a lot of #69 bonded nylon, unless extra strength (or extra thickness) is needed. Then, they'll switch to a machine loaded with #138 bonded nylon. Marine upholstery sewers avoid nylon where the material is exposed to the Sun and outside elements. Instead, they sew with bonded polyester thread, which is a lot more expensive, but isn't as affected by UV rays or wild temperature swings.
Might I ask what you want to sew? I can recommend the best range of thread sizes and types based on your expectations and type/model of your sewing machine. Some sewing machines cannot handle anything larger than #69 bonded thread. Others can go up to #138, or even #207. The big machines that we refer to as 441 clones are able to sew with very heavy bonded thread, all the way up to #415. That is about the same size as the linen thread used to sew leather soles onto boots.
Posted IMHO, by Wiz
Thanks again Wiz, the references to items helps a lot. I'll be sewing pockets on cases, and general bag work. Nothing super heavy duty (8oz + 5oz). Wallets and belt edges.
From what I've gathered 138 would be a viable choice for cases and bags with 207 being used if extra strength is needed. And 69 for pocket items like wallets and such.
I'm getting a 227 from Bob in a couple of weeks.
Chuck
Chuck
I agree with your thread size choices. Always use a thread size (or combination) that allows you to bury the lockstitch knots well inside the layers. Needle size can affect the position of the knots considerably. If the needle is the minimum size for the top thread, the knots will be harder to pull into the bottom. Go too big and the knots may appear on top.
So, what kind of sewing machine are you using for these bags?
Posted IMHO, by Wiz
A cowboy 227. I went back and forth with the consew 206 flatbed class machines, and almost got talked into a 441 clone, but its more machine and capacity than I need. The 227 gives the cylinder arm advantage and with a flatbed attachment for wallets etc, should be good to go for my needs in a machine. Down the line I might add a big machine if the need arises.
Chuck
Okay. The CB227 is a good medium duty walking foot machine. It can handle all the thread sizes you will need for sewing belts and bags, and vests, zippers, hems, etc. All you need is a full range of needles and thread for the work you will be undertaking. Extra bobbins is a must when you start using multiple colors and I always keep quarts and small precision bottles of machine oil in the shop.
Posted IMHO, by Wiz
Sounds good! Bob is sending an invoice in the morning.
Thanks again for all your help Wiz, it is much appreciated.
Chuck
