Yes, as long as the machine is able to run at slow speeds, under 600 or 800 rpm without running out of oil. Some modern straight stitch machines must be run over 2000 rpm to distribute the oil to the important extremities..
Wiz could you expand on this? It seems many of us slow our machines down for more control and power. It is rare I hit 10 stitchs per second unless I am on a long straight run. Now I am worried about oil starving my new 206.
What wiz is saying (i believe) is that there are some machines that are automatic oilers. They have oil in the pan under the machine and they use a pump to move the oil to the extremities of the machine. The pumps are powered by the movement of the machine. If the machine is not moving fast enough, the pump may not be able to move oil everywhere. If my 206 you mean the consew 206rb, then that shouldn't be a problem because I don't believe that machine has an oil pump. Please correct me if I'm wrong.
As for regular straight stitch machines, are there different classes of machines like a walking foot? Are some designed for heavier materials than others or are they all kinda the same?
Andrew
Andrew, yes consew 206rb-5. It does have an oil reservoir, but I cant tell through the little window if its a wick or a pickup tube in there.
Snip
Andrew
Yes and no, Andrew. The average straight stitch industrial sewing machine is built for sewing soft material that is not sticky, with cotton or polycore garment thread. I am talking about dresses, shirts, pants, aprons and such. Most of this work is done at very high speed, where time is money. High speed machines need self-oilers to keep them from seizing during long production runs. Springs for both thread and foot tensions are usually light duty, to handle the soft cotton thread used in garment production.
That said, some types of straight stitch machines are and were built for heavier and slower speed uses, with beefed up take-up levers and connecting rods, bigger bearings, manual oil ports. Think about the ancient Singer class 25 machines as an example. These are cylinder arm machines, with very heavy moving parts, a large roller foot, heavy duty springs all around, a very large cylindrical bobbin and the ability to sew with #346 thread.
Modern equivalents of the Singer 25K series include the Cowboy CB2500, Techsew 3650 and the GA5-1 that is sold under various brand names. These machines are 25K clones, with modern improvements like a reverse lever, harness foot or roller foot option, and tech support (if bought from a reputable dealer). They are priced lower that the 441 clones, and a little higher than the average upholstery grade walking foot machines. With large tooth feed dogs and heavy hold down springs, these machines can lay down a tight stitch into about 7/16 inch of real leather, with #346 bonded thread. The only reason you don't hear more about them is because they leave deep tooth tracks on the bottom and maybe foot tracks on top, both of which can be smoothed out with some elbow grease. Also, some holsters exceed 7/16 inch and these machines just aren't meant to sew, feed, and hold down anything much thicker.
One other limitation of the aforementioned machines is that they all use a needle system which has a #23 needle as the smallest leather point available (which is for use with #138 thread). This means no thin work with thin thread (wallet interiors, thin finished wallets, thin pouches, patching, typical zipper replacement, etc.).
Posted IMHO, by Wiz
Hey Wiz, I have a question for you, hopefully, without hijacking the thread.
I have access to several oil sump machines, and even have a Singer 281-3 laying around here somewhere (came with an industrial K-leg stand that I used for something else). I don't know much about the auto-oilers, but there was a lingerie factory here for a long time, and they used industrial machines that sewed dainty fabrics. They auctioned them off, and they're scattered all over the county now. Some buyers thought that they were leather-sewing machines, (and didn't realize that they had 3-phase motors on them), so they turn up for sale every once in a while.
My question is, if you run an oil sump machine slow and occasionally, do you really need to use the automatic oiling system, or can you just service it like a non-auto-oiler? Folks have bought gallon jugs of Lilly White sewing machine oil from me to fill their sumps, but they may only use the machine sporadically. Is oil in the sump under those conditions really all that necessary? Have you had much experience with this type of machine, even though they don't have much to do with sewing leather?
CD in Oklahoma
"I sew, I sew, so it's off to work I go....."
My sewing machines:
Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
