Boriqua Posted July 18, 2013 Report Posted July 18, 2013 (edited) I have someone asking for a holster that can be used both as in the waist band and outside. He wants to be able to completely remove the loops when it is used OWB. If I understand how to attach loops then it is like the drawing I posted. I have done a good deal of wood work and get this But how do I go from that to removing the loops entirely?? I'm baffled Edited July 18, 2013 by Boriqua Quote
Members Eagle Crest Posted July 18, 2013 Members Report Posted July 18, 2013 do you have a drawing of the pattern you are going with. it would help answer your question if we knew what the holster looked like Quote
Members glockanator Posted July 18, 2013 Members Report Posted July 18, 2013 (edited) You have the right idea. Use the t nuts that you would put a brad through and an 6-32 screw it should fit in most snaps and can be removed This tgread might help http://leatherworker.net/forum/index.php?showtopic=48230&view=&hl=&fromsearch=1 Edited July 18, 2013 by glockanator Quote
Boriqua Posted July 19, 2013 Author Report Posted July 19, 2013 (edited) On 7/18/2013 at 9:46 PM, Eagle Crest said: do you have a drawing of the pattern you are going with. it would help answer your question if we knew what the holster looked like Its just a standard pancake nothing special. The only trick was removing the loops entirely. You can see under the loops that it has slots for a belt. I really dont like the set up but they want something like it. Glockanator. Thanks man. I was hoping for some way for him to remove the loops easier but your right the only way I see this going down would be if he took a screw driver to it remove the screw and remove the loops.. Edited July 19, 2013 by Boriqua Quote
Members Dwight Posted July 19, 2013 Members Report Posted July 19, 2013 You will have to use some imagination with this drawing, . . . created with Windows paint, . . . BUT, . . . basically you create a standard pancake holster, . . . nothing extra on that. THEN, . . . you create a strap that would thread through the loops of the pancake, . . . and also hold on a swivel rivet, . . . a belt strap at each end, . . . converting it into an IWB holster with loops. That strap goes around back (looping around each end of the holster) and snapping on the back to keep it secure. Again, . . . crude drawing, . . . and it only shows one end. You do the drawing twice to get the full idea. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Boriqua Posted July 26, 2013 Author Report Posted July 26, 2013 (edited) Thanks GUYS and thank you for taking the time to do the drawing Dwight. Now stupid question number fifty. I have made IWB with one strap and that strap was integrated into the throat support so it was unable to pivot. Using the T nut and spaced wont the straps pivot around the t nut? Is it supposed to or are the straps supposed to be fixed? Hope that makes sense. Alex Added a simple drawing. So question is are those straps supposed to pivot? Edited July 26, 2013 by Boriqua Quote
Members glockanator Posted July 29, 2013 Members Report Posted July 29, 2013 If the strap.is righted down it will not move. Quote
Members Dwight Posted July 29, 2013 Members Report Posted July 29, 2013 It doesn't really matter if it does pivot (I use snaps, . . . no TEE nuts) and all of mine pivot, . . . but once the belt is laced into the two straps, . . . gun inserted, . . . belt pulled taught, . . . it ain't going anywhere. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
