Members motetra Posted July 22, 2013 Members Report Posted July 22, 2013 I have an artisan Toro 4000. I am no seemstress and I am not a pro leather worker either but I like to make a few things here and there. My Artisan is skipping stitches on latigo- its very difficult to sew. It has started to skip stitches on the smaller stuff as well. I have adjusted the tension, changed needles, changed the bobbin, done more practice pieces, ect. I am just at a loss of what to do next. Please help me before I go insane! Quote
Members Dink Posted August 6, 2013 Members Report Posted August 6, 2013 Sorry I am no help but have experienced the same thing, and tried everything you mentioned. I am wondering about using extra thread lube to see if that works. How thick are you sewing? I am sewing three pieces of about 12oz. Quote
Northmount Posted August 6, 2013 Report Posted August 6, 2013 (edited) Hard leather may have pushed your needle bar up. Then even thin or soft leather will be a problem. Did you have a jam? Wizcraft has a number of suggestions posted for many problems, search his posts. One suggestion he gives is to loosen your needle screw, drop the needle a little, may 1/8", tighten the needle in that position and see if it sews okay. If it does, you need to reset the needle bar. Tom Edited August 6, 2013 by northmount Quote
Members motetra Posted August 6, 2013 Author Members Report Posted August 6, 2013 Thanks, I will try that Tom. It did start with sewing an 8 ounce leather to about the same in latigo. Quote
Members Dink Posted August 7, 2013 Members Report Posted August 7, 2013 I can swutch back over to a thick veg tan breast collar and stitch without a problem Quote
Members motetra Posted August 14, 2013 Author Members Report Posted August 14, 2013 Moving the needle down worked great. I was making a bronc halter and took the thread out, ran it through to get the holes, rethreaded and it sewed beautifully. Thanks for the help. Quote
