Members xilli007 Posted September 4, 2013 Members Report Posted September 4, 2013 Hi guys, I recently acquired an old Rodi hand skiving machine. My plan with it is to refurbish it completely and make it functional again. After some adjustments, cleaning off some rust, sharpening the knife, oiling bits etc it finally skives and splits leather successfully! The only problem I find is that it leaves quite severe marks on the back..... Has anyone got any experience with these machines and knows how to solve this problem...? I was thinking of grinding off the ridges of the feeding wheels but I'm not sure it would remain enough 'strength' to feed the leather in properly.... Any help greatly appreciated!! Quote
electrathon Posted September 4, 2013 Report Posted September 4, 2013 As a test, wrap tape areound the wheel before you grind on it. Quote
Moderator Wizcrafts Posted September 5, 2013 Moderator Report Posted September 5, 2013 That machine is a shoe sole skiver. It was not meant to skive craft leather. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members pcox Posted September 5, 2013 Members Report Posted September 5, 2013 If you grind them off it's junk. Quote
Moderator bruce johnson Posted September 5, 2013 Moderator Report Posted September 5, 2013 Pcox is right. Don't grind, you can mess up the spacing and won't work. It looks like the bottom wheel is a driver. If so then you could get a wheel made by a machinist that is smooth for the top. A friend of mine got one made for a wide American for $40 last year. These will work with one driver. They will do vegtan and firm latigo OK with a good sharp blade. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members grail Posted September 3, 2015 Members Report Posted September 3, 2015 Is this RODI the same? I want to know if it can cut an angled channel into sole leather - please see photos. There seems to be lots of screw adjustments on it... AND I see it has a vertical knife too. Quote
Members grail Posted September 3, 2015 Members Report Posted September 3, 2015 Will it cut a side angled channel as is seen here for shoemaking? Quote
Moderator Art Posted September 4, 2015 Moderator Report Posted September 4, 2015 I don't quite understand. Are you trying to cut a channel in the insole for laying in a welt or is it another operation. I've always used a american channel tool (knife) and a flat bottomed french skiver (with or without the outside toe ground off, kind of like a straight version of a rand/welt knife tool) to carve out the actual channel. Like I said, I might not understand. Art Quote For heaven's sakes pilgrim, make yourself a strop!
Members Oakley Posted September 5, 2015 Members Report Posted September 5, 2015 I have/ had a few of these machines. I think there's no proper solution to get rid of these marks, that's the way it works and transports the leather. These machines were designed to skive and cut welts, here you have no problem with the marks. You can't cut an side angled channel with these machines, for that you need a machine like a Junker Ruh R28. Quote
