Members rfkoen Posted September 19, 2013 Members Report Posted September 19, 2013 We have a Tacsew T111-155 machine. We are sewing 2 layers of 2-3 oz leather. We bought #138 thread and #22 needles. The needles are way shorter than the original needles in the machine. Did we get the wrong needles, or is there a trick to using these needles with the machine? Thanks for any help you can provide! Quote
Members tnawrot2 Posted September 19, 2013 Members Report Posted September 19, 2013 Are you using 135x17 needles? Quote
Members rfkoen Posted September 20, 2013 Author Members Report Posted September 20, 2013 The needles we bought are 135X17, but they are a lot shorter than the needles that were with the machine when we bought it. Quote
Members rfkoen Posted September 21, 2013 Author Members Report Posted September 21, 2013 Is there an adjustment we need to make on the machine to use the 135X17 needles? They just look so much shorter than the needle in the machine now. Quote
Moderator Wizcrafts Posted September 21, 2013 Moderator Report Posted September 21, 2013 Your machine must be modified to use system 190 Pfaff needles. They are 3/16" longer than system 135x17. These needles are good, but bend and break more often if there is anything misaligned between the layers being sewn. If all your work is properly aligned and secured, system 190 needles will allow you to exceed 3/8 inches of thickness sewn. But, since they bend and deflect so easily, make sure that the hook doesn't hit the needles as you sew. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Sunnyside Scott Posted September 22, 2013 Members Report Posted September 22, 2013 Put one of the 135 needles in and check the needle timing to the hook, while spinning it by hand. The person that you got it from might have been trying to use the wrong needles. I picked up a used Adler 167 and the person had 190 needles in it, it sewed fine forward but got totally messed up when it was reversed. After a few hours of internet searches I found out that it was the wrong needle and I simply had to readjust the timing for the 135 needled and it works like a champ. Scott Quote
Members suzelle Posted October 11, 2013 Members Report Posted October 11, 2013 Wow, this sounds similar to what is going on with my Pfaff 545, old machine but newly acquired. It's normal needle is the 190, but it came with 135x17 needles too. I wondered why. A friend came to help me and put a 190 needle in, dropped it down a bit in the needle bar (we did not move the needle bar though as I'm not sure how to do that yet) and the thing started making a stitch. So, there is hope for this Pfaf 545. I may not have to take it to the shop. Quote
Members Gregg From Keystone Sewing Posted October 11, 2013 Members Report Posted October 11, 2013 Just to be clear here; From the factory, Tacsew T111-155 takes a 135X17 (not a 135X7, shorter needle, but same shank, the part that goes up into the needle bar. Durkopp Adler 167/267 series take 134-35 (not a 135X17). Pfaff 145/545 take a 134-35, BUT take a 190R system needle for high lift machines, such as a 145-H4, or 545-H4. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Moderator Wizcrafts Posted October 11, 2013 Moderator Report Posted October 11, 2013 You need to choose which needle system you will be using in your machine, then adjust the height of the needle bar to meet the hook at the correct amount of lift past BDC. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members suzelle Posted October 12, 2013 Members Report Posted October 12, 2013 (edited) Gregg, regarding your comment about the Pfaff 545 H-4: This info you gave is true, but not clear, because there is more to it than that. The Pfaff 545-H4 will take either the 190 needle or the 135x17 needle. I don't know about other machines, but this is the case with the Pfaff machine that I have. Just to be clear here; From the factory, Pfaff 145/545 take a 134-35, BUT take a 190R system needle for high lift machines, such as a 145-H4, or 545-H4. Edited October 12, 2013 by suzelle Quote
