The garage sale ad on Craigslist said ,,,industrail (sic) sewing machine so of course - since I was going to be within a mile - I stopped by.
Next thing I knew I was driving away with this thing in my van.
A quick check of my wallet revealed that I did not pay a lot - so at least I have that going for me.
It's a Singer 269W7 which, apparently, is a Shoe Tacker.
Having never worked on shoes, and being a total novice to leather swing in general,I have no idea what I might use it for.
I mainly thought the stand would be good for the Adler 30-1 I acquired last week. Now that one I understand :-)
Any information or guidance will be most appreciated!
post-41320-0-74611400-1381629250_thumb.j
post-41320-0-64225900-1381629252_thumb.j
Very nice! Nothing like that goes on in my neighborhood, everything starts at 700 on up :(
Have you tested it already? What kind of tacks makes it?
I´m also thinking of buying one ....
I have not tested it. I was enroute to a job and didn't have a lot of time.
Everything turns over but there's no thread holder etc..
I'll have to rig it up this week and see what and how it does.
What's it used for in shoe making?
This would be the first time an "industrial" at a yard sale turned out to be something other than this...
post-41320-0-65450500-1381670515_thumb.j
Edited by LewSchiller
That machine is known as a bartacker. It does just one thing: it sews a tight zig zag, approximately 5/8 inches long. The resulting stitch resembles a bar, thus the name. These machines are used to sew (tack) Velcro or webbing onto other things. It is not a shoe machine, per say. You cannot modify the stitch it sews. It is a one use machine.
Posted IMHO, by Wiz
Thanks Wiz!
Any idea what the maximum thread size would be?
Thanks Wiz!
I operated one in 1989 - 1990 that used #69 bonded nylon. That's what we stocked, and I suspect, that's the probable limit.
Posted IMHO, by Wiz
The 269 series of bartackers includes a wide variety of machines and what they do differs. Each subclass does a slightly different thing. The 269W7 is a shoe tacker and can make tacks 1/8" to 3/8". It uses an 18 stitch cam because of the narrow width. Moving up to the common belt loop tacker uses a 28 stitch cam and is adjustable from 1/8" to 1/2" but can usually be fudged out to make a decent 5/8" tack. We use a 42 stitch tacker for back pockets on jeans. 42 stitches destroys a 3/8" belt loop. I'll be honest with you, maintaining these machines to work properly is not for the novice. Timing the hook is the easy part. Making everything else happen when it's supposed to is another. Don't get me wrong, these have been a real workhorse over the years. Levi Strauss was heavily involved in the various versions to better automate their jeans production. I use them for belt loops, the front fly, and line tacking over the end of a one piece waistband. There are several different size needle plates and clamps. Your machine has no tying stitches which is the last stitching on most bartacks. This prevents cutting the leather by repeating the same path as the initial staying stitches. It's a cool find, but I like your idea of using the table for another machine. :)
Regards, Eric
