cody1200 Posted October 17, 2013 Report Posted October 17, 2013 Hello I have been having trouble with buying belt buckle sets that include buckle, keeper, and tip. I buy 1 1/2" buckle sets and cut my strip 1 1/2". The problem comes along when you put it all together and the strip is to wide for the keeper and the tip. So to fix this I either take a 1/4" off the strip or just tapper down the last 8 inches or so of the belt tip. My question is what do you normally do? make a 1 1/2" belt actually a 1 1/4" belt or what? thanks Quote
Members Dwight Posted October 17, 2013 Members Report Posted October 17, 2013 After screwing up 3 or 4 good belts, . . . I learned to very carefully cut the very end of my belt to go into the tip. The tip is designed to be the same size as the belt, . . . so since there is metal there, . . . you have to cut away leather to make way for the metal. Also, . . . I don't do 1 1/2 belts, . . . I do 1 7/16, . . . because all of mine are double layer, . . . and if you do a double layer 8 oz, . . . you can run into belt loop difficulties, . . . which isn't fun. Cut a strip of scrap leather, . . . 1 1/2 wide, . . . and outline the tip on the end of the strip. Cut that, . . . then begin by taking 1/16 off each side the length of the tip. A dremel tool with a sander also is a super help, . . . or a 1 inch belt sander, . . . you just have to be really careful with sanding. I prefer to cut, . . . Eventually you get what you need to make it work, . . . outline it on a piece of manila folder, . . . and you have a pattern for the next one you do. Final tip, . . . after you set the little screw(s) in the back of the tip, . . . rub your finger over them to make sure there are no burrs, . . . sand em off if there are. Those little burrs will ruin the face of the belt the first time the guy uses it, . . . and he WILL BE angry with you. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members cgleathercraft Posted October 18, 2013 Members Report Posted October 18, 2013 Final tip, . . . after you set the little screw(s) in the back of the tip, . . . rub your finger over them to make sure there are no burrs, . . . sand em off if there are. Those little burrs will ruin the face of the belt the first time the guy uses it, . . . and he WILL BE angry with you. ^^^ I found this out the hard way. Luckily on my own belt! Quote http://www.cgleathercraft.com Member of the Iron Brigade.
cody1200 Posted October 18, 2013 Author Report Posted October 18, 2013 Alright that answers my question perfectly thank you. Quote
