Members camano ridge Posted October 26, 2013 Members Report Posted October 26, 2013 (edited) Charles, I know you were looking for a response From Mike, however since I stumbled across this first I will tell you what I know and Mike can had his information in. The Avenger style is believed to have begun with the Milt Sparks 55BN. It became popular style and many major manufactures began making them they became more of a style in vogue when Bianchi in conjunction with input from Col. Charles Askins began to produce one with a fairly extreme FBI cant this style is comonly refered to as the Askins Avenger. The things that make it an Avenger Style are that it is a fold over with a trailing wing to the rear that has a belt slot and there is a belt loop on the back of the holster giving two atachment points. The re enforcement piece is utilitarian in that it is meant to help keep the mouth of the holster open for reholstering. The re enforcement piece can be decorative but that is not a requirement to make the holster an Avenger. If you google avenger holster you will find many examples the thing they all have in common is the foldover with the trailing wing belt slot and the belt loop attached to the back of the holster body. Edited October 26, 2013 by camano ridge Quote https://www.facebook.com/CamanoRidgeCustomLeather?fref=ts
Contributing Member SooperJake Posted October 26, 2013 Contributing Member Report Posted October 26, 2013 Kat, What I have been using is the waxed nylon thread. I saddle stitch most of my projects. Should I not be using the waxed thread? The sealer I use is probably giving the "plastic" look. I use Tandy's Super Sheen and usually do 2 coats. All of my dyes are the Tandy Eco Flo dyes. I know I am probably going to catch holy hell for that but my reason is simple I have to watch what products I use and what fumes these products. I hit the health lottery not only do juggle issues with the MS but severe asthma as well. Eco Flo doesn't send me into an attack. The other reason is cost it's cheap and when you're on a limited income cost comes into play. So if there are things I need to change let me know I am willing to try new things I just have to stay within parameters. My leather shop if you will is the upstairs landing. Don't have a garage to work from like a lot of guys do as well. I've had decent results with Eco Flo " PRO" as long as I pretreat the leather with Bick 4 conditioner, wait 10 minutes for the conditioner to soak in, then apply the Eco Flo with a sponge just barely wetted. I also blot off the sponge on paper towel to remove excess material. The leather doesn't absorb water as easy after, so for wet forming you need to soak it more. Quote Once you know what the magician know.... it isn't magic anymore.
Members katsass Posted October 26, 2013 Members Report Posted October 26, 2013 (edited) Charles, camano ridge has said it perfectly. It's just your basic folded holster, with the addition of a wing with belt slot, plus a stitched-on belt loop on the back of the holster. It is a very concealable holster to wear, They posses the ability to keep the front of the holster tight to the body, arguably better that most other styles The reinforcement is rather redundant IMO, but it now has morphed into an (almost) mandatory palate for damned near any form of decoration you can come up with. I personally believe that the reinforcement was the result of Milt saying to himself, "well, after the belt loop is stitched on, how do I make the damned thing look decent, and the belt loop not being just an afterthought?" I am quite sure that Milt and those that followed after, (Bianchi, etc.) were not at all worried about the collapse of the mouth of their holsters, after all, they had been making damned good holsters for years without the problem OR even the thought reinforcement. The only place that I can think of that the problem with the mouth of the holster actually collapsing, is on an IWB rig. As far as that goes, I have some personal opinions on that style, which others may feel a point to argue over. I think I do have a bit of an edge on many folks on here, in that I have been able to watch the evolution of holster design(s) since the 1950s. I've seen 'em come -- and go, and in my opinion, I'll mostly stay with the old traditional designs - with slight modifications here and there. Mike Edited October 26, 2013 by katsass Quote NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!! At my age I find that I can live without sex..........but not without my glasses. Being old has an advantage.......nobody expects me to do anything in a hurry.
Members charlescrawford Posted October 26, 2013 Author Members Report Posted October 26, 2013 Ok this is making a lot more sense now. Thanks to both of you for explain this out. Thing are a heck of a lot clearer now. Quote
Members leatherjunkie Posted October 29, 2013 Members Report Posted October 29, 2013 everyone gave you some great information. but wondering why no one mentioned evoo(extra virgin olive oil) as a finish oil? also there are natural dyes you can make for dying your projects. for example you can use used coffee grounds, walnut hulls and rusty water for old time dyes. the vinger black dye may not work for you due to the smell of vinger. i also have great results using leather balm with atom wax as a finish. you can get it from tandy. Wyosheen is the new name of Neat Lac since tandy does not carry it any more. it has a very harsh smell but it works real good as a finish. the following link is to cas city that has a lot of information on making old time dyes in your house: http://www.cascity.com/forumhall/index.php/topic,11991.0.html Quote keep it in the 10 range or at least hit the steel.
Members J Hayes Posted October 29, 2013 Members Report Posted October 29, 2013 Charles you can get yourself a good 3M paint respirator for around $30-$40 that may allow you to use anything smelly and not affect your breathing. It could very well open up airbrushing and other tjings to you as well. Quote
Members camano ridge Posted October 29, 2013 Members Report Posted October 29, 2013 The problem with using cartridge filter masks or APRs is that it may cause other problems for people with asthma as you have to work harder to breath through a filter you are drawing the air through the filter cartridges, some people with respiratory conditions can become fatiqued more easly. The powered air purifying respirators work pretty well for people with asthma and other respiratory conditions however they are more expensive. Quote https://www.facebook.com/CamanoRidgeCustomLeather?fref=ts
Members J Hayes Posted October 29, 2013 Members Report Posted October 29, 2013 Ah. I never thought about the added resistance, I wear one daily and just never noticed, but I don't have breathing issues. Thanks for pointing that out. Quote
Members camano ridge Posted October 30, 2013 Members Report Posted October 30, 2013 Not a problem, I wore breathing aparatus for thirty years and have taught and still teach classes on the various types of breathing aparatus and their limitations. SOrry for straying from original post. Quote https://www.facebook.com/CamanoRidgeCustomLeather?fref=ts
Members charlescrawford Posted October 30, 2013 Author Members Report Posted October 30, 2013 It is something to definitely look into. To be honest I never even thought about this avenue. When I use to sharpen skates I would wear one years ago and I always felt a bit claustrofobic but I would imagine things have improved since then. I know tomorrow I see a ENT to see why I am having chronic sinus infections that are are moving into my airways. So while y'all are tooling away I get the "joy" of having my sinuses scoped..... Yea me lol Quote
