Tree Reaper Posted October 26, 2013 Report Posted October 26, 2013 Just letting folks know that you can skive with a cheap block plane but the blade has to be sharp. Quote
Members Renoir Posted October 26, 2013 Members Report Posted October 26, 2013 great idea - would probably give a nice flat surface too. "Blade has to be sharp" - applies to pretty much all leather cutting! My results improved greatly once I learnt how to properly sharpen a knife... Quote
Tree Reaper Posted October 27, 2013 Author Report Posted October 27, 2013 Good control with the plane. It stops cutting after a few layers then you just lower with a slight turn of the screw, no waves, nice and flat. For sharp knives you can't beat a good cloth wheel and green compound, it takes seconds to sharpen a blade. Quote
Contributing Member Bob Blea Posted October 28, 2013 Contributing Member Report Posted October 28, 2013 What a great idea! I've got two of those kind of block planes. Think I need to try and get that blade really sharp. Thanks for posting this. Bob Quote
Tree Reaper Posted October 28, 2013 Author Report Posted October 28, 2013 You're welcome Bob. If you lay your straps out and clamp the far end to keep the tension it's quite simple and the results as you can see in the picture are better than you would think. I've skived a few dog collars and this was the first belt blank but I know now it works well and am happy to share it. If you don't have a blade jig or stone you can most likely get your blades sharpened at any saw sharpening service. I have a few different planes and chisels so I bought a jig and the wet stone. Quote
Members Hillbilly tim Posted October 29, 2013 Members Report Posted October 29, 2013 Planes are also valuable for squaring or leveling stacked glued leather too. better than trying to control a knife while trying to straighten up the lines of a project. Bro Timothy Quote
