Members Tiffany Posted January 21, 2008 Members Report Posted January 21, 2008 I'm trying to practice my handstitching on some 14oz saddle skirting and having a devil of a time punching the holes. I wet the leather beforehand and it cut relatively easily but trying to use the Tandy 4 tong punch is just impossible! I got the idea to use a thin drill bit in my dremel and "pre-cut" the holes before using the diamond shaped awl..seemed to work pretty well. Is this a correct method or is there an easier way? Thanks! Quote
Ambassador Beaverslayer Posted January 21, 2008 Ambassador Report Posted January 21, 2008 Trying to put holes into 14oz leather is going to be very hard with the 4 prong punch. I'd stick with the dremel and drill bit method, it will most likely take the same amount of time as trying to pull that punch out of such thick leather. Ken Quote Beaverslayer Custom Leather<br />Wearable Works of Art https://www.facebook...erCustomLeather
Members Randy Cornelius Posted January 21, 2008 Members Report Posted January 21, 2008 Your awl must be super sharp to go through shirting. If you try to use a Tandy or Osborne awl straight out of the box it will not work good for you. They must be sharpened and polished to work good. I use awls from Bob Douglas which are much better but cost a lot more. You can make a Tandy work but you must be good at sharpening. Use a wet stone and sparpen to a needle sharp point, keeping the diamond shape as you go. Then polish with rouge. You might want to get the Stolhman book on hand sewing lots of helpful tips. Good luck Randy Quote Randy Cornelius Cornelius Saddlery LaCygne, Kansas Randy & Riley Cornelius Ride Hard, Shoot Fast and Always Tell the Truth...
Members Tiffany Posted January 21, 2008 Author Members Report Posted January 21, 2008 Thank you both for the wonderful responses. Quote
superchute Posted January 21, 2008 Report Posted January 21, 2008 I drill and then use two needles to sew it works great if to tight us a bigger drill bit works great russ Quote
Members YRsaddles Posted January 21, 2008 Members Report Posted January 21, 2008 the dremel tool works great and use it from time to time...but mainly when I'm hand stitching I use an awl and it has to be VERY sharp..most of the tools you by will have to be sharpened before use...all I use is saddle skirting...and if you can't go through several layers of skirting easily then the tool isn't sharp enough..remember this...a tool that isn't sharp enough will hurt you A LOT easier that one that is Dave Quote
Timbo Posted January 21, 2008 Report Posted January 21, 2008 The 4 prong punch you are trying to use was not meant for such heavy leather. Getting the leather wet helps punch the holes but distorts the edge. If you have the single diamond punch it will work better but be very tedious. As others have said the norm for stitch holes in skirting is a very sharp diamond blade sewing awl. I've punched thousands of holes with the 4 prong punch but it has limitations, mostly getting it out of the leather after it is all the way through. Tim Quote
Ambassador Don101 Posted January 21, 2008 Ambassador Report Posted January 21, 2008 Hi Tiffany here is a tip for you just get your diamond awl and some wax (any wax will do a candle ) and push tha awl into the wax then pierce the hole in the leather becarefull you will be surprised how it goes through like butter try it on a piece of scrap first, Don Quote
