Members Akhenaten Posted November 13, 2013 Members Report Posted November 13, 2013 Too often when I do a swivel cut and then bevel I see a line where the cut goes deeper than the beveling. Or if I hammer the bevel hard to get to the depth of the cut then I'm left with a large gap that looks funny. What am I doing wrong? Quote
electrathon Posted November 13, 2013 Report Posted November 13, 2013 Bad angle on your bevellers. Look at the Barry King Bevellers with a steeper angle. Quote
Contributing Member Bob Blea Posted November 13, 2013 Contributing Member Report Posted November 13, 2013 Also, you might be getting this because you are undercutting with your swivel knife. Make sure when you are cutting that you hold the swivel knife stright up and down, and not tilted to the side. I had a similar problem and it turned out I was leaning the knife over when making sharp turns. Bob Quote There are always possibilities.... Bob Blea C and B Leathercrafts Fort Collins, CO Visit my shop at http://www.etsy.com/shop/CandBLeather?ref=si_shop Instagram @bobbleacandbleather
Members Cyberthrasher Posted November 13, 2013 Members Report Posted November 13, 2013 Also, try not cutting as deep. If you're using a standard angle beveler, you'll get results like that if you try cutting really deep because the beveler has to move a lot more material. Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members Akhenaten Posted November 14, 2013 Author Members Report Posted November 14, 2013 Thank you all! I'll practice some more and consider upgrading my beveller. Quote
King's X Posted November 15, 2013 Report Posted November 15, 2013 I am a bit puzzled because this happened to me way back when. Do you have any pictures? Also, can you briefly describe your process for preparing your leather before you start cutting. My first response without thinking too much would be that you leather is not moisten down far enough which would the reason for the 'white' line. This would be the part that was not wet. Like I said, just my first response without too much thinking. Good luck Quote Greetings from Central Texas! The Grain Side Up blog #TheGrainSideUp
Members RiverCity Posted November 15, 2013 Members Report Posted November 15, 2013 I'm gonna throw my 2 cents in, and say it's partially due to the position of the beveler in the cut. If the heel is to close to the area that is being beveled around you will see the cut line in the bottom of the bevel. Try to keep the beveler straight up and down, with the edge of the beveler in the center of the cut. Undercuts etc will make it worse. Chuck Quote
Members Cyberthrasher Posted November 15, 2013 Members Report Posted November 15, 2013 I am a bit puzzled because this happened to me way back when. Do you have any pictures? Also, can you briefly describe your process for preparing your leather before you start cutting. My first response without thinking too much would be that you leather is not moisten down far enough which would the reason for the 'white' line. This would be the part that was not wet. Like I said, just my first response without too much thinking. Good luck Ah, I hadn't even thought of that one. Now that you mention it, I do remember that problem happening more back when I didn't know how to case that well. Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Contributing Member JLSleather Posted November 15, 2013 Contributing Member Report Posted November 15, 2013 No pictures? I didn't see you mentioned anything "white", but if we knew what "gap" you're referring to that would help. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Akhenaten Posted November 17, 2013 Author Members Report Posted November 17, 2013 Ya I haven't been casing properly... I was following the spray it down and tool method. Here's some pictures of the project I'm working on right now that has some of what I'm talking about. Quote
