Thanks for posting that, it will save some people a whole lot of time and research , and money..
An additional note for you, if you ever get the chance to get any of the older French made rivet / eyelet / grommet / snap setters made by "Daude", the setters are all 8mm threaded into the "piston" ( "the piston" itself has a very coarse "thread" lowers it in the cast iron frame when the integral handle is swung / turned ) that's the top part..the lower part of the "die" is held in place in the lower part of the casting by a small set screw. The lower "die" part on mine incorporates a tiny spring.
"Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
  • Replies 120
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
