Yup. I agree, any tool that doesn't work properly has no place in any shop. There are advatages for the craftsman if he/she knows how to maintain their equipment, sometimes there is less downtime if you can fix it yourself and you don't rely totally on a repair shop, nothing against them at all. There is also a point of diminishing return on repairing equipment yourself, just because you can fix it or make it doesn't mean it makes economic sense. Being able to time, adjust and replace a few things can be priceless and a huge timesaver, but having a machine that requires constant dickering would be a huge cost in lost time and production which equals money.
  • 3 weeks later...
  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
Agreed.
I am a Hobbyist though, so I do stuff when I can and want.
The Hook should be here Monday, so we are looking forward to having the machine working again!
Did some leather work regardless...
Practiced molding some leather gear knob halves...
And a Burgundy half too.
The parts arrived and were installed..
New Hook assembly, Tensioner assembly and bobbin cover.
Just for reference, her is a picture of the old Hook point against the new one...
Old.
New.
Stunning difference!
Anyway, the install went well, and I thought I would post a few pics and notes to help anyone who needs info.. or maybe tell us we were wrong!
It took us a while to figure out how the hook assembly is removed...
Its 3 screws...
There is a metal finger that holds the inner part in position, and that must be removed from below... 1 screw.
Then the 2 screws that hold the hook assembly to its shaft are loosened.
The inner basket is rotated, and this gives just enough space to get the hook off its driveshaft.
The new one is put on the same way.
Once the hook assembly is in position roughly, we put a needle in and carefully rotated the machine by hand(Belt disconnected) until the needle was at its lowest position.
We had the idea to mark that position on the hand wheel, just like a engine is marked on its crank pulley, in this case it would be BDC(Bottom Dead Center). We marked a spot on this oil hole with a black sharpie, and the hand wheel position with white paint marker.
Next, we used a pair of calipers to measure that point on the bottom of needle post... upper point on the calipers.
We recorded this as 17mm... but its just a reference...
The next thing is to add 2mm to this measurement, so we set the calipers to 19mm.
This is referenced back to the needle post as below.
You can see the caliper is now higher.
The machine is then rotated until the needle post comes up 2mm...
We took a moment to mark this position on the handwheel too.
We found this to be about 20mm from the BDC mark.
The manual states that when the needle has risen 2mm up from its lowest position, the hook tip should be in the middle of the needle.
We were close, but not perfect, so the two screws were slackened and the hook was rotated into the correct position, and then the gap between the hook tip and needle was set with feeler gauges... the manual states 0.05mm to 0.10mm, by moving the hook assemble along its shaft...
Everything was re-assembled after this, and the beast sews like a storm...
No missed stitches and no snarls so far!
Happy we are!!!!
Edited by Keyair
Here are 2 pics that refused to post yesterday...
Handwheel distance at 2mm rise.
Needle and hook Timing and gap set.
This would be a good time to make two marks on the needle bar. The marks will be 2mm apart from each other. The higher mark would designate the needle bar down position. A mark 2mm below it would indicate the 2mm rise to set your hook timing. Make the mark line up with the bottom of the needle bar bushing. This is the way most machines reference needle bar height and hook timing. If for any reason you need to remove the needle bar, you can quickly return it to the correct height without worrying or even checking the hook timing.
I set multiple hook timings every day. You develop a feel for where a given machine should be set. With experience, you'll find any timing references are a starting point to get you going. When you run into problems, (and you will) don't be afraid to stray from the absolute. I have a lot of lockstitch machines that aren't set to the book. It depends on the sewing conditions. Thread, material, thickness all can require a different hook setting. If you enjoy the learning process, all the more fun added to the sewing.
Regards, Eric
  • 2 years later...
Thanks Eric!
Been busy, so now getting back to sewing again!
Just bought 5 full hides in Dark Brown, and one in Pecan from a closeout sale to retrim the seating on my Motorhome.
Been messing with ideas for the styles, seams, and contrasts with the leathers and some uphostery materials I have...
Not decided yet, but here is what I tried so far...
Question:
Is the any reason why I can't use 207/210 thickness thread on this machine?
I like the way the thicker thread looks, and it seems to work ok sometimes, as long as I dont reverse!
17 minutes ago, Keyair said:
Question:
This is unlikely due to the way the hook and shuttle is constructed. Also, the tension and take-up cranks may not be strong enough to pull up the knots of thick threads. Also, you will need to move up to a #24 or 25 needle to use thicker threads and this makes it harder to penetrate and then hold down the leather.
Posted IMHO, by Wiz
I have a Consew 206, and I have fussed and fussed, a D I can't get it to run  #207  thread, so I stick with #138.
I'm using a JUKI LU562 and it sews fine with 92.  I switch to 138 and my upper tension has to be soooo tight, it seems out of range.  Granted, I'm use PTFE Tenara thread, which Is so slippery.  My Singer 107W! hates the stuff and misses too many stitches.
I think the LU562 is in the same range as these Consews.
I too am tired of tinkering and would love a 100% working machine.  Spending a hour on dinking with the machine is a waste of $$
JUKI LU562, Singer 107 W1, Thompson PW201 mini walker, a couple of plastic fantastics for light duty "home stuff".... ya know...fixin' and altering clothes.....
