MadMorbius Posted November 24, 2013 Author Report Posted November 24, 2013 It seems to have gotten much better with the above adjustment and further tightening of the top tension but I believe I've hit the point where it's not getting any better now regardless of what I do...diminshing returns as it were. Quote
Moderator Wizcrafts Posted November 24, 2013 Moderator Report Posted November 24, 2013 Back off the bobbin tension spring until the thread flows smoothly with about half the current force. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
MadMorbius Posted November 24, 2013 Author Report Posted November 24, 2013 Backed it way off..and it doesn't seem to be making any measurable difference to how the stitch is coming out a this stage. I'm getting very, very frustrated with this process Quote
Moderator Wizcrafts Posted November 24, 2013 Moderator Report Posted November 24, 2013 Are you using a leather point needle? Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
MadMorbius Posted November 24, 2013 Author Report Posted November 24, 2013 (edited) Gave up on the stirrup plate and tried to revert. Now I'm missing sitches. I changed the needle and adjusted the tension, re-threaded the machine....I'm about ready to jump out a window. EDIT - Note to self and others reading....make sure the needle is *completely* inserted before freaking out and thinking you have a timing problem. Time to walk away from this for awhile...back to mostly normal operation for now. Wondering if my stirrup plate issue was also related to the needle being improperly reinserted after I pulled it out to check the size Will try again later. Edited November 24, 2013 by MadMorbius Quote
MadMorbius Posted November 24, 2013 Author Report Posted November 24, 2013 On a side note, while we're dissassembling and reasembling stuff...what constitutes the "correct" height for the feed dogs when one reinstalls them? Ron, Wiz, all of you...thanks so much. You've been very patient and it's greatly appreciated. Quote
Moderator Wizcrafts Posted November 25, 2013 Moderator Report Posted November 25, 2013 According to the manual, the feed dog teeth should be about 1 or 1.2 mm above the plane of the throat plate, at their highest point. However.....Some of us set them flush with the top of the throat plate, for mystical reasons, known only to Mr. Peabody and Sherman. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
MadMorbius Posted November 25, 2013 Author Report Posted November 25, 2013 (edited) Ok, that's about where I put it..In my trial and error I found that having them higher seems to add a bit much pressure on the work and may actually keep it from moving forward consistently. I'm going to try installing the stirrup plate again tonight...feeling pretty rediculous about going through all that yesterday only to find that the needle wasn't fully inserted...AFTER I gave up and reinstalled the normal plate. We'll see... The type of work I intend to do with it is the same as pictured in my profile picture. I can't move the center gusset around the machine to stitch around that curve with the formed gussets on either side of the seam, it winds up butting against the bottom of the machine and inhibiting the feed. Really hoping this plate resolves that and is worth the effort Edited November 25, 2013 by MadMorbius Quote
Techsew Ron Posted November 26, 2013 Report Posted November 26, 2013 Hi Rob, check your email, we did some troubleshooting for you and sent instructions. Ron Quote Techsew Industrial Sewing Machines Call toll-free: 866-415-8223 Visit www.techsew.com
Moderator Wizcrafts Posted November 26, 2013 Moderator Report Posted November 26, 2013 Ok, that's about where I put it..In my trial and error I found that having them higher seems to add a bit much pressure on the work and may actually keep it from moving forward consistently. I'm going to try installing the stirrup plate again tonight...feeling pretty rediculous about going through all that yesterday only to find that the needle wasn't fully inserted...AFTER I gave up and reinstalled the normal plate. We'll see... The type of work I intend to do with it is the same as pictured in my profile picture. I can't move the center gusset around the machine to stitch around that curve with the formed gussets on either side of the seam, it winds up butting against the bottom of the machine and inhibiting the feed. Really hoping this plate resolves that and is worth the effort The stirrup plate is what you need to sew curved gussets. Once you will get past the thread loop position problems, you'll laugh at this beginner's speed bump. Have you ordered some leather point needles one size larger? This may solve the loops on the bottom problem. Did you know that leather points are available in more than one shape? I use mostly type S, but also have some triangular "diamond" points on hand. They produce a different top and bottom stitch. One more thing: you might try adding some more top pressure to the feet. If the leather is not absolutely pressed down against the stirrup plate it will usually have bad results on the bottom. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
