Members DarthBubbles Posted November 29, 2013 Members Report Posted November 29, 2013 Hey All, I need a better hole punch. Not only for my edges before I lace, but I would like to be able to go through thick layers of fabric for the corsets/bodices that I make. I do a lot of items that need to be laced together and I am looking for a solution that doesn't necessarily require me to punch the 4 holes, lift, move to the right, re-set (one in the hole), punch again. Has anyone ever used a power hole puncher? Here is a link: http://www.amazon.com/Neiko-Power-Punch-Sheet-Metal/dp/B0002T87CW What I use: Regular Heavy Duty Rotary Hole Punch. Craft Tool Drive Punch. Tandy's Craftool Hand Press. 4in1 Leather Punch. Thanks in advance, Jennifer Quote
Members Sturme Posted November 29, 2013 Members Report Posted November 29, 2013 that looks like a metal hole punch, wouldn't it leave leather fibers around the back, not cutting a clean hole? Quote
Members DarthBubbles Posted November 29, 2013 Author Members Report Posted November 29, 2013 The metal cutters that I have seen before don't seem like they would. Right now I am looking for anything that might help. Do you have any other suggestions? In my old age I find that I am getting some gnarly hand cramps. Quote
MadMorbius Posted November 29, 2013 Report Posted November 29, 2013 I would not recommend that punch as it's designed for sheet metal applications - it will probably scar both the front and the back of the leather. I have to confess I'm not entirely clear on your use case or the problem you're having. For lacing, I use a lacing chisel that punches a half dozen slots at a time. For lacing with heavier lace (latigo for example) I use either a rotary punch or a drive punch. For belts and other repetitve work I make a template to lay out the hole locations, then knock them all out one after the other. If I had the funds for a clicker, I'd use a die to punch out the pieces with the holes in place at the same time. Quote
Tree Reaper Posted November 29, 2013 Report Posted November 29, 2013 A small drill press and a forstner bit would make that easy work , depending on how secure the fabric is. If the fabric is loose it won't work but if it's glued in place it will. Putting holes in leather is a piece of cake. Quote
Members Red Cent Posted November 29, 2013 Members Report Posted November 29, 2013 (edited) Darthbubbles, it occurs to me that a thin piece of plastic placed above and below the leather would work with the tool. It also occurs to me the cheapest would be pieces of plastic milk jugs or the like. If you have a drill press (wouldn't cost too much) then Reaper's idea is good. Matter of fact I intend to pick up some bits. Harbor Freight has them cheap. The drill presses run about $70.00. http://www.harborfre...peed-60238.html Matter of fact, you could place the chisel in the drill press and use the drill press (turned off) to punch the holes with the chisel for the thick stuff. Ideas. Every one has them............. Edited November 29, 2013 by Red Cent Quote https://www.facebook.com/redcentcustomleather?ref=bookmarks http://www.redcentcustomleather.com/
Members DarthBubbles Posted November 29, 2013 Author Members Report Posted November 29, 2013 Red Cent...your my new hero genius. Quote
Members Red Cent Posted November 29, 2013 Members Report Posted November 29, 2013 awwwww shucks. Quote https://www.facebook.com/redcentcustomleather?ref=bookmarks http://www.redcentcustomleather.com/
Members Hillbilly tim Posted November 29, 2013 Members Report Posted November 29, 2013 Why dont you use a heavy sewing machine with big needle installed and NO thread. it will punch lots of holes in a line one after another. Bro Tim Quote
Tree Reaper Posted November 30, 2013 Report Posted November 30, 2013 (edited) Why dont you use a heavy sewing machine She's using lace. Edited November 30, 2013 by Tree Reaper Quote
