Members Leatherpownder Posted December 14, 2013 Members Report Posted December 14, 2013 4 Pass Pineapple Scarf Slide. Quote
Members TXAG Posted December 15, 2013 Members Report Posted December 15, 2013 That is really nice...how do you dye your rawhide? What size strings are those? Quote
Members Leatherpownder Posted December 15, 2013 Author Members Report Posted December 15, 2013 I dye with RIT. That sting is about 1/16". Quote
Members bucksnort Posted December 15, 2013 Members Report Posted December 15, 2013 Really nice & a good way to use short pieces. Buck Quote
Members Tracym Posted December 15, 2013 Members Report Posted December 15, 2013 Nice! What do you do with the ends, so nothing can come loose? Quote
Members Leatherpownder Posted December 15, 2013 Author Members Report Posted December 15, 2013 Usually run under at least three strings to finish. Quote
Members Tracym Posted December 16, 2013 Members Report Posted December 16, 2013 Thanks. But sorry, I'm missing something - run under strings, wouldn't it just be loose there in the center? Or are you going "between" some strings (under some over some) if that makes any sense? Come up to the outside of the knot then cut off? Quote
rcsaddles Posted December 16, 2013 Report Posted December 16, 2013 That is very nice. Quote Joe Boyles Rugged Cross Saddlery Lewistown, Montana Romans 6:23
Members Leatherpownder Posted December 17, 2013 Author Members Report Posted December 17, 2013 I'm not smellin' what you're stepping' in. The tail end should meet where the start end is so I go over the start end with the tail end but under three strings of the knot. All the strings should be tight. All there is under this knot is a leather collar and I tie the knot on the collar while it is on a 3/4" x 4" wood dowel. Quote
Members TXAG Posted December 17, 2013 Members Report Posted December 17, 2013 Tracym -- If I've understood the books I've read correctly, you basically continue the pattern right on top of the standing end, running it under three strands (at least), then cut the excess flush. ...again -- if I'm understanding all these books correctly. Quote
