Rediculously Simple Question : Sharpening A Swivel Knife
I agree about the SK 3. It is likely the best you can find. If you do not have the money for it, the more economical quality choice is a Barry King knife.
I have an SK 3 and it is my go to knife for everything. Rarely have to do more than strop it to keep it in good working order. I also have Barry King's knife and it is good and I use it for certain things (I have several beader blades for it and I like it for decorative cuts), but my Leather Wranglers knife is my #1 tool.
There are always possibilities....
Bob Blea
C and B Leathercrafts
Fort Collins, CO
Visit my shop at http://www.etsy.com/shop/CandBLeather?ref=si_shop
Instagram @bobbleacandbleather
Seriously.. there's a knife sharpening CLASS? :rofl:
As a used-to-be toolmaker, I've sharpened a LOT of stuff, using things from sandpaper to surface grinders. But when it comes to leather, I need a blade that cuts smoothly without drag. But I can do that for what... $3 (ish)? When they're dull, I pitch 'em and replace 'em. I think I've sharpened enough :)
My interest is the look and usefulness of the leather when I'm done carving. Not what name is on the side of the knife. Or the mallet. Or whatever.
Guy tells that story... Fella is blowing insulation in the walls of his house, decides he needs a drill.
Go to the store, and the guy tells him this drill is $19.
Next one is layin' there, and the guy tells him this one is variable speed, and it's $29.
A third model is variable speed AND reversible, and its $49.
One has all that, and hammer drill function, and it's $129.
So, the question was... which one does he need? Most people when asked that question say "the cheap drill". But what he actually needs is holes in the wall - which he could do with a hammer.
5 leather patterns
So, Bob and Electrathon. What makes the SK-3 better than others? What makes a knife bad, good or great? I have large hands and some arthritis setting in. I have been thinking of the newer Tandy Pro with the large barrel.
I strope mine before and after every use with a bit of jeweler's rouge and a scrap piece of veg tanned leather, both rough then scarf side. It keeps it razor sharp every time.
As far as putting an edge on a completely dull blade, as cheap and readily available as they are, I would just replace it with a new blade and maintain it properly if it were me.
Knowing how to properly sharpen all types of blades is a skill everyone who uses them should master nonetheless.
Tom, so here's what I've learned from talking to Paul Zalesak at Leather Wranglers, who has done a lot of research into what is actually happening when our blades get dull. He found that what really creates the drag we feel in a dull knife is the corrosion and pitting that the acids in the leather cause on the sides of the blades. When we strop the blade, we are microscopically polishing those pits back out and that works well until they get to the point where too big for the stop to polish out or you fold the edge over and need to put on a new edge. So what Paul did was hunt down a steel that is very resistant to corrosion and he found a special alloy that resists corrosion extremely well. It's also very hard, so it will maintain its edge for a long time. The problem with the Tandy knife is its a low carbon steel so it corrodes easier and has a softer edge, hence you need to work harder to maintain it. It can still work well for you, but you will need to maintain it a lot.
Bob Blea
Fort Collins, CO
I'll chime in and confirm what Bob wrote- I spent a while on the phone with Paul a good while back and he told me almost exactly the same thing. As to what makes a good knife - quality materials and funtionality. The SK3 has both. It certainly isn't the only knife in the tool box for many people, but Paul has blended a lightweight barrel with a very smooth (ball bearing supported) yoke. Then the addition of his super secret allow blade yields a knife that is easy and comfortable to use, and also doesn't require a whole lot of upkeep. That last part means that your time can be used for carving leather instead of working on your blades.
The other low maintenance option is a ceramic blade. By the simple choice of a non-steel blade, dulling by corrosion is removed as a factor. However, they are NOT 'ready to go' as they are purchased. There is a good article by 'Shtoink', that examines how and why ceramic blades need to be sharpened.
Mike DeLoach
Yes to all Bob said.
If you like to sharpen a lot and like knife drag, any chunk of low carbon steel will cut leather. A great blade will take a very sharp edge, will keep a sharp edge for a long time, will not corrode when expose to the stuff in leather that causes corrosion. The SK3 blade does all this. Knife conversations tend to fall along the quality verses the cheap all the time. Some people are content using their beginner kit Tandy knife forever. Other people like the feel of precision as they cut. It is a lot of personal feeling. Have a top chef try using a gensu knife and he will have trouble preparing dinner. Have a beginner use the chefs knifes and he will likely end up with Band-Aids all over. I do tend to agree to a point that beginners are usually content with beginners knives, they have not yet learned to feel the difference.
Paul tells the story often about the perfectly dull knife. He has had people buy a knife from him and complain that it cuts right through the leather. They are so used to using a dull knife they have never learned proper pressure and end up slicing right through. So for those people he strops the blade, taking off the very tip. They now have a knife that is only sort of sharp, will stay exactly like that for years an everyone is happy.
Here is a good sharpness test. Go to the edge of your leather and try to skive off the edge to a slight bevel. If your blade is sharp it will do this effortlessly. If it is not sharp it will be hard to control and hard to be consistent on your skive.
