Members TXAG Posted February 3, 2014 Author Members Report Posted February 3, 2014 TXAG, I think you're gonna have a harder time if you hate all the major leather suppliers. I don't hate them all...just two. Quote
Members ASM Posted February 4, 2014 Members Report Posted February 4, 2014 I've used Fiebings Saddle Lac on bracelets, and Ipad cases and have good results, especially if you are using water based finishes. Nice shine and very water resistant. Quote
Members GrampaJoel Posted February 5, 2014 Members Report Posted February 5, 2014 (edited) I've had good results with this product. -->> http://www.sheridanleather.com/WyoSheen_p/wyosheen.htm But never tried it on a braided piece. Joel Edited February 5, 2014 by GrampaJoel Quote
Members Early2rise Posted February 13, 2014 Members Report Posted February 13, 2014 Neatlac is now sold under the name clear lac and is available from panhandle leather. If you're using it in something that will flex a lot, cut it 50/50 with the thinner and apply lightly with a piece of sheeps wool. The traditional finish for whips is said to be shellac but I have had less than desirable results. It looks good for a while but then starts to flake off and is very spotty. Any finish you choose will eventually crack or flake if applied to heavily, especially with a lot of flexing. Quote
Members Peter T Posted February 13, 2014 Members Report Posted February 13, 2014 Yes, shellac can deliver poor results if not done well. Some of my early attempts ended up flaking a bit. After a couple of bad results I realized I was putting it on too thick. Here's the brew I use as was taught to me by a champion whipmaker (plan ahead if you want to use it). Half fill a container with shellac flakes. I use a big instant coffee jar. Then put in enough methylated spirits to fill the container. Give it a shake every couple of days and let it settle (this might take a week or so, hence plan ahead!) Pour off the liquid that looks like a strong cup of tea into a jar. However much you've got, double it with methylated spirits and then you have your brew. To apply, pour some on to a lint free cloth and rub it onto the whip. After a minute or so when it is dry, give it a light roll, then give it a buff with a soft cloth. Repeat that step. After the third application, no need to roll anymore, just buff when it is dry. For working whips, 3 coats is about right for a nice shine without overdoing it. For show whips, I might do 5 or so. Since using this method, I've never had any of the issues that I experienced early on. I very much like the shine and feel it gives. Takes a bit longer to do than a coat of leather lacquer but for me, it's worth it. I know some very good whipmakers that use lacquer and their whips also look very nice, so that also works if done properly. Pete Quote
