The black one is dyed, in 1956 the Army switched from brown to black leather so they have dyed a lot of brown equipment black.
J.Q.M.D mean Jeffersonville Quartermaster Depot - but I guess you know that ;)
In making such a pouch and minimizing leather and weight, you can sew that using the left foot that rides on the edge of the leather and use the presser foot as your guide.
There's another foot you can buy from Toledo Industrial Sewing machines and maybe even from Cobra Steve.. It is called a paddle foot and they come in either left or right toe. I have both.
Paddle feet allow you to sew with the inside foot up against the raised case, on the left, while maintaining firm contact with the narrow sewing flange on the right. With a few exceptions (e.g. sharp corners), they won't push off the edge as happens with the standard right toe presser foot.
Paddle toe feet:
post-11118-0-31234400-1392874440_thumb.j
These feet may not be the same height as your current set and may require some readjustment of the large crank arm on the back of the faceplate. It takes the large hex driver that came with the Cowboy and Cobra 441 machines.
post-11118-0-01357300-1392875079_thumb.j
It's possible that no amount of adjustment of the crank on the back will bring the paddle foot all the way down, especially when sewing thin leather. If this is the case, you'll need to remove the faceplate and reposition the presser bar downward. This rarely happens to me as most of the shaped cases I sew with the paddle foot are about 3/16 to 1/4 inch thick along the flange. The foot can be adjusted with the big crank arm to reach the bottom and raise the inside foot sufficiently at that thickness.
Posted IMHO, by Wiz
  • 2 weeks later...
right toe
post-39507-0-94116900-1394162343_thumb.j
