Members Colt W Knight Posted March 14, 2014 Members Report Posted March 14, 2014 (edited) I broke down and bough a set of for DiaSharp stones, Ex coarse, coarse, fine and extra fine. I really bought these to level and dress frets on a guitar. before that I used a double sided norton stone. I can sharpen a knife just as sharp on a norton stone as I can my DMT diasharps. My dad had his Norton stone for 20-30 years before I bought him a new one to replace it. If those nortons gets wavy, you dress them back sharp again. Diamond stones are great, but I don't see the need for the expense unless you are sharpening a lot stuff. Good things. 1. Fast and precise 2. They don't groove like a stone 3. Heavy - so they don't move around bad things. 1. They are heavy, so it hurts my wrist when I try to hold the stone in my hand and shapen 2. expensive 3. I had a carrying case made for my stones, and they stayed in my truck for a long time. I wore off some of the diamonds in a few spots were they rubbed in the case. If you use them enough to sharpen, the diamonds will wear off. DMT makes that super clear on their website. * I also finish my edges with a ceramic steel after honing the edge on my stones. For a long time, I use a burned out High Pressure Sodium bulb filament from some very expensive lights used on strip mining equipment. Edited March 14, 2014 by Colt W Knight Quote
Members Toolingaround Posted March 14, 2014 Members Report Posted March 14, 2014 Hi David For what it is worth sharpening is the bane of my leatherworking because I suck at it but I have gotten way better (including touching up our kitchen knives) since I got a double sided diamond plate (fits in my pocket) and a Viking wet stone I wear around my neck from https://www.ragweedforge.com/SharpeningCatalog.html Ragnar is a legend for being able to sharpen anything and his favorite tools are the little diamond plate and the stone. That Viking stone is phenomenal by the way! He does have bench stones when he needs them if he really has to fix a blade but most of the time he uses the little plate and the stone. By the way if anyone loves "scandi" knives like I do you should definitely check out his web site! I have one of the wood carving Mora's from him that I use as my main leather cutting knife. His prices are the best, he is a super nice guy and he KNOWS sharpening! He will answer your questions. He also sells many other stones too. Cheers, Toolingaround Quote
Members Tex Shooter Posted March 14, 2014 Members Report Posted March 14, 2014 I like a 1 x 2 x 8 very fine Norton India stone. I use the edges for small tools, that way I keep the sides flat for planer blades. Arkansas does not work well on stainless and I have found that I can not get as good of a edge with even a very fine diamond. -- Tex Quote Tex-Shooter - Winner of the 2003and 2004 Summer Nationals Slingshot Tournament. -------------------------------------------------------------------------------- Too soon old/too late smart -------------------------------------------------------------------------------- “It is better to remain silent and thought a fool, than to open ones mouth and remove all doubt” Abraham Lincoln -------------------------------------------------------------------------------- My YouTube Channel ----- slingshotbill's channel - YouTube
Members David Bruce Posted March 14, 2014 Author Members Report Posted March 14, 2014 It's interesting and frustrating how everyone's opinion on sharpening differs. I have been holding off on sharpening with my Norton oil stone in fear that I would ruin my tools. I think that I will give it a try and if it doesn't do the job I can always get DMT's, etc... Quote Singer 111w155, Consew 206RB-1, Cowboy 3200, Fortuna Bell Skiver, Landis 30, Campbell Keystone Skiver, Dixon Skiver, American 3 in 1, 2 Kwikprint Model 86's and Model 64, Clicker Press, Regad Heat Creaser, Merrow 60W, Singer 114W103 and an addiction to hand tools
rawcustom Posted March 14, 2014 Report Posted March 14, 2014 Just have to say that I've been making and sharpening knives my whole life. Part of my policy with the knives I make is that I maintain them for free for life including sharpening, and most of my local repeat customers I'll sharpen anything else they bring me as well. There is more mysticism and general BS regarding sharpening then there is fact. Your best source of information is the research done by John D. Verhoeven where sharpening was studied scientifically. It's very easy to get caught up in natural hones that according to the price must be assumed to have some imbued great properties, but there is nothing magical about a creating a fine edge. All you are doing is polishing two opposing faces. The evenness and angle in how those faces meet, and the degree of polish will equal your end result. Here's why I like bench stones: Less variables. A huge struggle in sharpening is maintaining the same angle on each pass of the stone. If you hold a stone in your hand now you have just added a new set of XYZ movement to your sharpening method. Can it be done? Sure, but for learning and consistency, eliminate half your variable, half the problem and use a bench stone. Here's why I like Diamond course plates: Fast and Flat. You won't wear them uneven, no dressing required and they work incredibly fast. Working fast is also great because it means you spend less passes on the hone, and therefore introduce less variable angles. I assure you the faster you get your edge established the better it will be. All the extra angles work to round your bevel over and therefore work against your efforts. Here's why I like ceramic: Flat and Finish. Spyderco ceramics give a great finish without much extra time. Their medium stone is considered open coat and they state it may need to be dressed (this must take a lot since mine has stayed flat) but they guarantee their fine and ultra-fine to never need dressing. Can I get equal polish from an Arkie? Yes, but slower, much slower. Can I get equal from Japanese water stone? Yes, but more maintenance in dressing stones, and prepping stones. After a Spyderco UF, a few swipes on a strop with chromium oxide and you have a complete surgery ready edge. There is some debate over a flat sharpened bevel vs an elliptical or convex sharpened bevel. My advise on this is always attempt to create a flat sharpened bevel. Two reasons for this, first I can promise that you will already have a somewhat elliptical bevel if you sharpen by hand because you are not a machine. Second, the argument I have read on this is that the convex offers a longer lasting edge. Let's suppose this is true but you start with a perfectly flat bevel. Over time as you maintain the edge it will naturally wear into an elliptical shape, and it will be easily maintained until the elliptical grows too great from too much worn off edge. This is where it is dull and you re-sharpen. If you start with an elliptical edge, you're going to reach that dull edge a lot faster since you skipped the whole wear into an elliptical stage. Quote
Members Colt W Knight Posted March 14, 2014 Members Report Posted March 14, 2014 (edited) I agree about all the sharpening mojo/mysticism out there. I think it is becoming a lost art for most folks. When I was a kid, my dad gave me a dull pocket knife so I would learn how to take care of one without cutting myself. What did I do? I went down to the creek and found a flat stone and sharpened my little pocket knife. When I showed my dad, he took it away, and I didn't get another one till I was about 11-12. He showed me how to use his norton stone once, and I spent a lot of time sharpening every knife I could get my hands on. I even sharpened friends and family knives. Once I got the hang of it, I was able to sharpen a knife fairly quickly and effectively with just a simple two sided worn out norton stone. When I was 16, a gentleman at my family's horse stable gave me a brand new long double sided norton stone for always sharpening his knife. I really thought I was something using an actual flat stone to sharpen a knife. I was so obsessed with sharp knives for while, I carried a HPS bulb filament in my pocket to constantly dress my pocket knives.I still keep my knives sharp, but I got burned out sharpening things. I just do it know when I have to, and I don't volunteer to sharpen stuff for other anymore. I understand the principle of the convex/concave edge thing, but once the knife is dull, I would think sharpening a convex edge would be a royal PITA. I would probably end up working it into a normal flat edge. Edited March 14, 2014 by Colt W Knight Quote
hidepounder Posted March 15, 2014 Report Posted March 15, 2014 I prefer to use the diamond plates. I've tried a lot of the other stones and I always end up going back to the diamond plates. I've also discovered that stropping mechanically with Brownell 555 black rouge (thanks to Terry Knippsheild) saves me a lot of time an effort in keeping my head knives and straight knives sharp and usable. I'm not against the use of india stones or water stones and the like, but I've discovered that they are not as time efficient or practical for me when using a knife everyday. Quote
Members simontuntelder Posted March 16, 2014 Members Report Posted March 16, 2014 I have a belt sander and polishing set up already. But I would like some diamond sharpening stones. What grits should I be buying? Oh, and does anybody know of a good UK or European source? Quote
terrymac Posted March 17, 2014 Report Posted March 17, 2014 I prefer to use the diamond plates. I've tried a lot of the other stones and I always end up going back to the diamond plates. I've also discovered that stropping mechanically with Brownell 555 black rouge (thanks to Terry Knippsheild) saves me a lot of time an effort in keeping my head knives and straight knives sharp and usable. I'm not against the use of india stones or water stones and the like, but I've discovered that they are not as time efficient or practical for me when using a knife everyday. Bob, The 555 works as well on a strop for swivel knifes. Knipper recommended using latigo rather than veg tan, and it certainly spreads smoother on the latigo. Do you think you have enough compound to last a while? Terry Quote
hidepounder Posted March 17, 2014 Report Posted March 17, 2014 Hi Terry, I have enough to last me for a while. I don't use 555 to strop my swivel knife (although it would work really well) because it just isn't necessary. Swivel knives develop corrosion from the residual chemicals in the leather and a couple of strokes on green rouge cleans it off. The act of stropping is what dulls the blade so I use the finest rouge I can find. My head knives and trim knives take a lot more abuse. I prefer to use food grade belting for my swivel knife strop because it doesn't compress and round the edge of the blade. For my knives I use a paper wheel with 555 on a grinder motor. It's really fast an easy! Quote
