holmesmarsh
Help With Border Lines
Please can someone tell how do I make these edges on my border lines look better
post-45376-0-95376400-1396474733_thumb.j
The bottom line looks like it got flattened out by a hand or something that was resting on it.
The other two aren't bad but long steady runs are better than short strokes with several stops in between.
Bevel the line. You can bevel it inwards or outwards, depending on if you want the serpentine to look recessed or stand out from the surface.
Chuck
Make sure it is properly cased, too wet will do what your bottom line did, especially if you rest your hand on it like Tree Reaper says.
Tom
