Members jgibbs Posted April 10, 2014 Members Report Posted April 10, 2014 Hello,I am new to working with leather and have been having lots of problems cutting straight strips from my buffalo leather. I find that because this leather is kind of stretchy I am having problems getting everything really straight. I have tried using a metal ruler and a sharp knife as well as the leather strap cutter and just can't seem to get it right. If anyone has any tips and tricks to help me out that would be awesome. Quote
Members Red Cent Posted April 10, 2014 Members Report Posted April 10, 2014 36" metal ruler, a strip of wood 2"x1" (as long as the ruler), and two hand clamps. Quote https://www.facebook.com/redcentcustomleather?ref=bookmarks http://www.redcentcustomleather.com/
Tree Reaper Posted April 10, 2014 Report Posted April 10, 2014 You can tape down the outer edge with masking tape and use a few lighter passes with a very sharp blade applying pressure straight down. Quote
Members DavidL Posted April 10, 2014 Members Report Posted April 10, 2014 I second the rotary cutter. Olfa makes the sharpest blades by a good margin. Quote
Members jk215 Posted April 10, 2014 Members Report Posted April 10, 2014 Heavy top pressure on your straightedge and light passes with sharp blade. Quote http://shop.makesupply-leather.com - Custom and Stocked Acrylic Templates
Members rmr Posted April 10, 2014 Members Report Posted April 10, 2014 I use a fair amount of buffalo on shotgun cases and shell cases- so I know your pain. Not sure what the application of your leather is for- but in mine- I will glue some 2-3oz veg tan lining leather to the inside of the buffalo - as a liner but also to give it some stiffness/ hold its shape better- then if I need a straight line I cut it and the line comes out perfectly straight- I use a sharp 3" head knife. Cut the lining leather to the exact size shape I want- then glue to buffalo, then trim buffalo to lining leather. Not sure this will work for your application- but has worked well for me Quote
Members jgibbs Posted April 10, 2014 Author Members Report Posted April 10, 2014 Thanks everyone! I will try these suggestions and let you all know how it works.Thanks again! Quote
