Members MonicaJacobson Posted June 25, 2014 Members Report Posted June 25, 2014 I tried hot rod striping on a bag, but it was the first time and the only time, so I'm not saying I represented it very well. (Also, I hadn't sealed the bag yet, and the edges are terrible, so... yeah...) Quote http://monicajacobson.com/ https://www.etsy.com/shop/TrimGoTrix?ref=si_shop
Members Solofalcon Posted June 25, 2014 Members Report Posted June 25, 2014 I did look up a pinstriping design to stitch into an archery arm guard in conjunction with some Celtic knot work. This may not be exactly what your looking for but may be a different approach. Quote
Members Dwight Posted June 25, 2014 Members Report Posted June 25, 2014 Probably if it were my project, . . . a set of plastic (clear) French curves, . . . and a hand stitch gouger would by my approach. Figure out which part of the curve to use for which lines, . . . lay out the start and end points for each line beforehand with a pair of dull dividers, . . . use a piece of masking tape at the beginning and the ending of each curve to mark where you start and where you end. Depending on the size, . . . that shouldn't take too long that way, . . . and following the French curve, . . . it's hard to mess that up if you take your time and really, really pay attention. Painting in the stitch gouges is kinda tricky, . . . but it would look really nice when it was done. I'd probably use a hypodermic needle and some really thinned down paint, . . . maybe have to do a couple of coats, . . . but just track through the gouge line, . . . emitting a bit of paint as you go. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Greg528it Posted June 25, 2014 Members Report Posted June 25, 2014 My first thought would be to stitch the pattern with red and white thread. Second thought, a stitch grooving tool run free hand to the pattern. Or I my self would sand blast the pattern using photo resist. It would also be real easy to paint with the resist still on. Quote
Members ikewineb Posted June 25, 2014 Members Report Posted June 25, 2014 David, what's a header blade? I think a gouge tool would be the way to go. They are adjustable, so you could vary the depth and therefore the width of the lines. Personally, I would simply antique it. I've never used paints though. Quote Ike Winebarger www.southboundleather.com
