Members MojoGeorge Posted May 17, 2014 Members Report Posted May 17, 2014 Dunno if you have already got the side or nit, but spfd leather will strap cut the side for you cheap, ask for rusty Quote 'Ware the Penguins!
Members Dwight Posted May 17, 2014 Members Report Posted May 17, 2014 For both squaring and cutting a straight line, . . . I have my work table covered in a 36 inch by 60 inch plastic top that was designed for ladies who sew a lot. It is marked off in 1 inch squares, . . . with 1/8 inch gradations, . . . and it makes cutting a straight, square, or even angled cuts "piece of cake" easy. I also have the aforementioned large aluminum ruler, . . . together they make big cuts, . . . long cuts easy. The cutting surface came from JoAnn fabrics, . . . with their 40% off coupon it was only like $25, . . . which to me was a super bargain. It is "attached" to my table top by double faced carpet tape, . . . so if it becomes damaged, . . . it is easily replaced. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
