Members DavidL Posted June 1, 2014 Members Report Posted June 1, 2014 Are brass hammers safe for use on metal pricking irons - not deforming the top or teeth? They are cheap from harbour freight if I'm ever in the USA (2lb hammer) and can make a good impression in one hit I'm imagining. My 1 lb soft rubber mallet sometimes needs two hits, making it hard to make the holes the same size - If I hammer too softly it needs a second hit, in some cases I overcompensate and the hole is too large. So I'm looking at 2 lb hammers, a medium strength hit will get the proper sized hole or are 1 lb hard plastic mauls the way to go? ...... Is it also safe to use a solid metal block under a pricking iron? Quote
Members papaw Posted June 1, 2014 Members Report Posted June 1, 2014 Yes it will work just remember not too hard of hit, it will not deform the top the points are what you have to watch out for hit to hard and you could break one not because of the force but in the movement of creating that force with brass you'll not need the force because there is no bounce. I use my dead blow hammer 1 lb for the ones I do my is mostly awl work. NO NO metal under pricking iron - poly board with steel would be ok as long as poly is thick enought. Quote Papaw Indiana Calumet Area Leather Guild Happy to be old enough to know better, but young enough to still do it !!
Members DavidL Posted June 1, 2014 Author Members Report Posted June 1, 2014 I'll go with a 1.5 - 2 pound brass. from bottom to top: Thick log metal plate 1 inch pound board Scrap leather piece Is this a proper set up? I want there to be no bounce from the hammer to the pricking iron and no bounce from the base. I can't see why it won't work, to be on the safe side I thought id ask. Quote
Members Macca Posted June 1, 2014 Members Report Posted June 1, 2014 learn to use an awl & pricking iron together properly & you won't have these problems, as Ive posted repeatedly, they are not meant for what you are using them for You are still trying to use a pricking iron like a chisel to make the holes, so now you are having hole sizing issues due to the taper, well thats because too much of the iron is going into the leather. You get away with punching slits all the way through on thin leather, you don't on thicker. If you want to punch stitching holes with irons get the Japanese ones, they have parallel teeth & make diamond holes (waits for the inevitable replies from people who use them like this or get mixed up between a pricking iron & a chisel !) Quote
Members DavidL Posted June 1, 2014 Author Members Report Posted June 1, 2014 (edited) The way I do it I prefer to hit it all the way through on single pieces. If I do multi layered I mark one piece all the way through (3/4 ounce leather), then glue the other pieces on and stab through or use another iron and hit the backside, the middle piece is unmarked and I stab from one side to another where there are grooves on back and front so that every stitch is even. No way is the proper way. I can get good results doing it this way and the stitches come out how I want it to so I keep it like this. Only problem is the base in my setup and the hammer I'm using doesnt distribute the force evenly, so one side of the iron comes down deeper than the other. Some hermes workers hit the iron all the way through, a dunhill worker in a video i've seen hits it all the way through and other good craftsman I've seen do the same. In my opinion, and its only my opinion, If you hand stitch without using another iron in the back it will never turn out as well as if you haven't. The difference in is like drawing a straight line with a ruler vs trying to free hand a straight line by hand. No matter how straight I place my awl through the leather or vertically through w/ a foam board underneath taking extra time to make sure it is 100 percent straight, in a row of stitches of 50-200 at least 1-10 will be off in any direction by a mm or 2 and make the line of stitching look bad. Even w/ the iron on both sides the stitches don't come out perfect since it is hand stitching, but effects the margin of error. Edited June 1, 2014 by DavidL Quote
Members oltoot Posted June 2, 2014 Members Report Posted June 2, 2014 Safer than steel, not as safe as rawhide or poly Quote
Members Hi Im Joe Posted June 2, 2014 Members Report Posted June 2, 2014 In my opinion, and its only my opinion, If you hand stitch without using another iron in the back it will never turn out as well as if you haven't. The difference in is like drawing a straight line with a ruler vs trying to free hand a straight line by hand. No matter how straight I place my awl through the leather or vertically through w/ a foam board underneath taking extra time to make sure it is 100 percent straight, in a row of stitches of 50-200 at least 1-10 will be off in any direction by a mm or 2 and make the line of stitching look bad. Even w/ the iron on both sides the stitches don't come out perfect since it is hand stitching, but effects the margin of error. This is exactly why I have gone to the japanese pricking irons. They are much more consistent. It is damn hard to get every awl hole perfect from front to back. Quote http://www.sevenhillsleather.com/
Members Macca Posted June 2, 2014 Members Report Posted June 2, 2014 Agree it's hard Takes lot of practice, you do eventually develop a muscle memory that means the awl angle is repeated time after time & will look prefect Quote
Members Hi Im Joe Posted June 2, 2014 Members Report Posted June 2, 2014 Agree it's hard Takes lot of practice, you do eventually develop a muscle memory that means the awl angle is repeated time after time & will look prefect For sure! I do plan on using my osborne pricking iron in the future so hopefully I'll get better at it! Quote http://www.sevenhillsleather.com/
