Need to know the name of this tie and how to do it Thanks
post-22700-0-41904600-1403467496_thumb.j
I've heard it called both a bleed knot and a blood knot, . . . and I have no idea which if either is correct.
It is very simply done by making a slit in the bottom piece, . . . parallel to the edges, . . . just slightly longer than the width of the strap, . . . pull the top piece down through, . . . make the same type cut at about the same distance as the first cut, . . . but again in what is now the bottom piece, . . . pull the new top piece through it, . . . and you have the knot.
Take a key ring, . . . put a strap of leather around the ring, . . . follow the above directions, . . . the first one will take you 20 minutes, . . . the second should take you 2 minutes. It's really that simple.
May God bless,
Dwight
www.dwightsgunleather.com
Thanks folks you save my bacon on this. Needed a new way tie tie on to a powder horn. I'm a happy boy :)
In Bruce Grants book he just calls it a slit braid on p. 50 but what works is what matters.
Papaw
Indiana Calumet Area Leather Guild
Happy to be old enough to know better, but young enough to still do it !!
