Members CaptQuirk Posted October 21, 2016 Members Report Posted October 21, 2016 2 hours ago, Gordon said: How much do you allow for the width of of gun. I'm looking at a Ruger Security Six it's 1.5. The trick I learned, was to take a 1" strap of leather that is roughly the same thickness as what you will use. At one end, measure off a 1/2" (I use 3/4"), and draw a line across the width of the strap. Lay the pistol on top of the strap, with the bottom of the trigger guard on the line. Fold the strap over the pistol so that it hugs the curves, and mark the strap where it meets the bottom edge below your your half inch mark. Measure the distance between the second mark you made, and the bottom edge of the strap. That is how wide you need to make the holster pattern. You can also use this method for measuring the barrel. Quote
