Chief,
Great looking strap and nice finish explanation! What weight leather did you use?
Tom
Beautiful in its simplicity, very nice :)
Thanks,
Chief,
Tom
Tom, Thanks for the comments, the strap is made from 6/7 oz.
Chief
"Life's too short to carry ugly leather"
  • 6 months later...
Hi Chief-
I just did a guitar strap. Used several of your finishing tips, including the painters tape on the back. I did leave the tape overnight, pulled it off after work, Problem: the tape stuck pretty well and "fuzzed" the flesh side. Any tips for making the fuzz lay down and stay down tight again?
Really appreciate the tips. I looked you up on you tube- would like to see you do a finishing tutorial too. Or anything else that you would like to share,
Enjoyed your instructions...
Thanks again!
Hi Chief-
Thanks again!
Thanks eglideride,
Two things, 1) it matters which way you pull the tape (which direction), I start a corner and if it's pulling, I go to the other end. 2) it matters what leather you use, I always use Hermann Oak and the back is pretty clean and smooth to begin with. If you have one that is "fuzzed", then you can sand it lightly, going only in the direction the fibers lay and finally you could dampen it lightly and burnish it with a burnishing glass. I use one a lot for smoothing leather.
Hope that helps,
Chief
Edited by Chief31794
Ahhh!
> Not Hermann Oak- I will have to check into that as time and experience allow.
> Common sense- pulling with the grain- Duh!
Thanks!
  • Ambassador
really nice job on aligning the letters!!!!
Thanks Pete.
Chief
  • 2 weeks later...
