dbitting Report post Posted August 25, 2014 thought I would try to do some fancier lacing and coloring. Lacing is not the best in the world, but I am getting better. Quote Share this post Link to post Share on other sites
billybopp Report post Posted August 25, 2014 Not bad! Lacing takes a bit of practice to get it right. Keeping even tension on the laces is pretty important. I can't tell what you are using, but good lace gives a better result and makes the job easier. Calf and kangaroo are often recommended lace materials. One of the leatherworker.net members has done a good video on mexican round braid lacing that is pretty good stuff, and makes a very attractive edge. Take a look at it if you have the time! https://www.youtube.com/watch?v=ikoKfgm2SMw Hope that helps Bill Quote Share this post Link to post Share on other sites
dbitting Report post Posted August 25, 2014 it is some old lace that I picked up somewhere. It's called Tandy's grained duraflex. One thing I did not do is try to flatten the lacing after I got done.I will try to watch the video you listed. I appreciate the comments, I am still learning how to work on leather. Quote Share this post Link to post Share on other sites
benlilly1 Report post Posted August 25, 2014 Hi Dbitting, Here's a tip...make sure your edges are cut straight and the holes punched straight so the lacing will look better. Quote Share this post Link to post Share on other sites
MonicaJacobson Report post Posted August 26, 2014 I like how you attached the belt clip. Quote Share this post Link to post Share on other sites
dbitting Report post Posted August 26, 2014 benlilly1, I tried to do that, I used a lacing chisel, I practiced using a regular stitching 4 hole punch and it went good, Monica, thank you, I looked at how others attached belt clip. I had been cutting a hole in the back and slipping the clip in, but it would scratch the lens of the phone. Quote Share this post Link to post Share on other sites
dbitting Report post Posted September 24, 2014 This is another cell phone case I made for a friend. She wanted a Velcro fastener and I sewed it in. I don't like sewing velcro. Quote Share this post Link to post Share on other sites
