Members AndiH Posted September 19, 2014 Members Report Posted September 19, 2014 I have a friend who can't wear belts because she breaks out when she touches metal too much. I decided I'd give it a try now that life seems to be getting easier again. My thoughts were to use a dowel secured to one end with lacing then a loop on the other to secure it. Ideally it needs to be adjustable, but all I've come up with so far is punching holes the length of the belt then lace from the each end through, but that doesn't really look too workable when I try to picture it. Any suggestions ? Quote
mlapaglia Posted September 19, 2014 Report Posted September 19, 2014 How about a single button stud on the chape(Buckel end) and cut the billet holes to make them work with the button stud. Since the chape is folded back to hold the keeper the metal to hold the button stud in place will not be against her at all but sandwiched between the chape with the back of the keeper. It would work \just like a regular belt with 5-7 holes just attach a little different. Its a thought anyway. Michael Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members DavidL Posted September 19, 2014 Members Report Posted September 19, 2014 (edited) one option is to wet mold leather to the buckle and stitch to hold it together. The metal rod that goes into the belt - a small rectangular piece of leather could be placed width wise (Glued and stitched) and she could use that leather bit to prevent touching the metal piece. Edited September 19, 2014 by DavidL Quote
Members Troy Burch Posted September 19, 2014 Members Report Posted September 19, 2014 why not just get a buckle blank and cover it with tooled leather Quote
Members AndiH Posted September 19, 2014 Author Members Report Posted September 19, 2014 Thanks for the ideas, David and Michael. Troy, I'm very much a newbie. I'm confident I can punch holes, but at this point thats about it. Hopefully life slows down now that summer's over and I can really get to work on this stuff (learning it I mean). Andi Quote
Members cgleathercraft Posted September 19, 2014 Members Report Posted September 19, 2014 I have the same allergy (specifically nickel). It is - not - fun. Especially when I found out that white tungsten carbide is bound with nickel. I now break out if I wear my wedding ring continuously. I still wear it everyday, just not when i'm sitting for extended periods. Belt buckles(and watches) also present the same issue to me. I've used tape (electrical and athletic), several coats of nail polish, and a few other types of clear lacquers. Nothing has worked better than just wearing and undershirt, and that is not always possible in the summertime. I suggest picking up a buckle designed to be wrapped in leather and lacing it around the edges. Here is what Tandy has to offer on it: http://www.tandyleatherfactory.com/en-usd/home/department/buckles/buckle-making-supplies/buckle-making-supplies.aspx Also really like this idea. How about a single button stud on the chape(Buckel end) and cut the billet holes to make them work with the button stud. Since the chape is folded back to hold the keeper the metal to hold the button stud in place will not be against her at all but sandwiched between the chape with the back of the keeper. It would work \just like a regular belt with 5-7 holes just attach a little different. Its a thought anyway. Buttonhole-Punches-Sample-3779.jpg Michael Quote http://www.cgleathercraft.com Member of the Iron Brigade.
Members Renoir Posted September 19, 2014 Members Report Posted September 19, 2014 My mum is also metal sensitive - any buckles or studs *touching the skin* are a no-no. Check out the ranger style belt - As long as there is leather backing the buckle you should be OK. I adapted this and made her a watch strap with a pad under the buckle and watch back - the first time she's been able to wear a nice watch for years (otherwise it's awful rubber straps, as most traditional straps expose the buckle or watch back). I've had a couple of ranger-style belts and worn them for years - more comfortable. It's on my list of projects to make next... Quote
Members Grumpy Coyote Posted September 19, 2014 Members Report Posted September 19, 2014 Rolled toggles. I use leather toggles all the time on bags, not a bit of metal needed. Also, you could use a loop and tie, or any thing else like that. Creative solutions to hard problems will sometimes make the best designs. Quote
Members AndiH Posted September 20, 2014 Author Members Report Posted September 20, 2014 Thanks for all the great ideas. I would have researched this before, but I was without net until they could get me a new modem (well that and life issues). Apparently I may have been over thinking it. Quote
robertmeco Posted September 20, 2014 Report Posted September 20, 2014 Here is a belt buckle you might use http://www.zackwhite.com/2-Prong-Mechanics-belt-buckle-insert--H8372NP_p_4864.html Quote
