Hi guys, I'm new into leatherworking and it has become very addictive to me :)
I made for myself a couple of gunbelts, with cartridge loops stitched in the classic method, but since I've bumped in this picture, I ve decided from now to make my future gunbelts with that system too, but I'm wondering if it's just enough cut the slots on the belt and place trough them the leather designed for the loops. Of course you have to rivet both ends, and line the belt, to avoid possible damage to the loops, I'm also asking if this method durable and if is going to hold firmly the cartridges. Looks to me indeed a save-time system since you don't have to stitch every single cartridge loop placement.
Thanks in advance for any suggestion and advice.
Cheers from Italy
Bruno
post-52032-0-54203800-1413754233_thumb.j
Edited by Bruno Rock
There are several methods for making cartridge loops. I seem to recall a thread discussing that, but can't find it at the moment. The method illustrated in your photo is fast and very attractive. It does have one serious weakness: once a cartridge is pulled out, it's possible for the adjoining loops to become loose.
That's what I feared about that method, I found out the others topics and alos this interesting pic
post-52032-0-60241700-1413805920_thumb.j
Actually, . . . not meaning to disparage TexasJack, . . . but if it is done correctly, . . . that cannot and will not happen.
First, . . . make sure the leather you are using for the loops is about a good 1/16 wider than the slots you punch. They then get pinched into the slot and don't move because of that pinch at the top and bottom because of the excess width.
Second, . . . pull the loops tight around the cartridges as you go.
Third, . . . contact cement your loops to a liner and sew the edges together to make your belt.
There is then no feasible way the loops will become loose by taking out a cartridge here and there. That is simply an internet rumor, . . . as far as I am concerned, . . . and if anyone saw it happen, . . . I'd chalk it up to sloppy workmanship on the belt.
May God bless,
Dwight
www.dwightsgunleather.com
I totally agree with Dwight and use this for belts that the customer wants to save some money......a good stitched set to loops just has a greater wow factor an makes the belt if done right in my book, which is pretty worn out
I don't know too much about these, but it seems that it may be a good idea, on style #1 and #2 above, to put a few stitches between each loop. You'd only need a small number of stitches: just enough to prevent the loops from "creeping", and it may also help the back part of the loops, inside the belt, to lie flat.
The look you want, and hand vs. machine stitching may be a factor in what you do as well. ( Not to mention your ability to get the slots cut perfectly perpendicular and evenly spaced ... which I suck at).
Stitches and slots both might be overkill, but if you're a belt AND suspenders guy it's a good thing.
Just a thought
Bill
From the picture of the OP, . . . it seems he is doing style # 2, . . . which IMHO, . . . is THE way to do them.
They will not get loose if done right, . . . they keep the rim of the cartridge from digging into the belt itself, . . . and they will get to a place where the cartridge is easy in / easy out, . . . but if you lay it down, . . . or tip over, . . . they won't fall out.
Stitches on that style is just overkill, . . . and a lot of extra work for nothing.
Actually the slots are pretty easy to cut, . . . if you have the "tool". It is a little home made "T" square that has marks for the top and bottom of the slot. It also has a little piece coming down from the top that shows the exact spacing for the next one. Makes the whole process a whole lot simpler.
May God bless,
Dwight
post-6728-0-66356600-1413824503_thumb.jp
Love the tool, Dwight! The only things I do with regularly spaced slots are guitar straps (so far), and that would be a tremendous help on some of the adjustable straps. I've been using a T-square, which helps get things perpendicular, but then spacing is still a bit touch and go. I'm gonna have to make one.
Thanks!!
Bill
Thanks, Bill, . . .
I make all my cowboy belts with a curve in them, . . . makes the top a tad shorter than the bottom, . . . makes it hug the hips better, . . . keep it from falling off.
Cowboys really hate it when their gunbelts hit the dirt.
I made the square originally so I could get that straight down slot from any place in the curve, . . . just have to make sure the front edge and the back edge of the top piece are equal distance from the edge you measure from. . . .
May God bless,
Dwight
...First, . . . make sure the leather you are using for the loops is about a good 1/16 wider than the slots you punch. They then get pinched into the slot and don't move because of that pinch at the top and bottom because of the excess width.
Third, . . . contact cement your loops to a liner and sew the edges together to make your belt....
As much as I hate to point this out, I am right. In order to KEEP the loops from slipping, you've gotta add all the steps Dwight listed.
I'm not saying you can't do this method, merely that it has it's weakness. Dwight is simply compensating for that.
