I am about to design a leather sunglasses/glasses case. I am concerned that the flesh side of the leather, which would be on the inside of the case, will scratch/mark/scuff the glasses. I am using full grain hermann oak, and the flesh side is very tight, not hairy at all. Is this something I should worry about? I really do not want to have to line the inside with suede or another material. Would it be reasonable to lightly sand the flesh side to make it softer? I had thought about that but I don't want any flesh particles to be left on the glasses (I don't even know if that would happen, just hypothesizing). Maybe theres a conditioner or something that can be used?
Thanks!
Zayne
Edited by zaynexpetty
You should line it with a soft fabric of some sort. Even felt is an option. If you can find a nice microfiber cloth, that should protect the lens nicely. Use a little spray glue to hold it in and stitch around the edges.
Hope this helps
Chuck
I think that's a good idea too... a nice soft microfiber cloth.
The soft microfiber cloths are really good to clean the glasses with too
~Cheryl
There are many things in life that will catch your eye,
but only a few will catch your heart...
pursue those...
Hmmm. If you were to put in a sewn microfiber cloth liner and attach it only at the case opening, you could pull it partly out to clean glasses with and then just shove it back in when done. That may work or not, depending on the case design. If it works it'd be pretty nice, tho!
Bill
Hope this helps
Chuck
I really like the idea of lining it with something, but I am trying to make the case look minimalistic, so I want to avoid having a lot of stitching. Is there a way this can be done without stitching/extra rivets?
Thanks
Bill
I kind of like that Idea, I do want to avoid having to line the whole case with stitches, but if I just had to do one line of stitches to hold the microfiber in place, that might work.
Thanks!
I could be wrong, but it seems like it might be easiest to
glue the lining in before stitching the case ?
I also think it would be a good idea to go lightly with the glue
so it doesn't dry hard... or maybe just a bit around the edges... ?
edit......
I was just looking around for more info on lining an eye glass case and found this info...
by northmount (link)---> Eyeglass Case Lining-Necessary?, How To?
"A lot of the scratches in plastic lenses are due to people using the same micro-fibre
cloth forever without cleaning it. Anything that rubs against the lens needs be soft & clean."
I might not have thought of this as I also have a residential and commercial cleaning business and
I launder my cleaning cloths daily... so what I use on my glasses is always clean.
After reading that other post I was thinking maybe it would be better to just lay the cloth inside the case
so it can be removed and cleaned periodically?
When I was a kid I had glasses with lenses that were made out of glass and they did not scratch easily.
After 30+ years of wearing contacts, I just had to get glasses (about 3 months ago) and they have plastic
lenses and scratch really easily.
It will be interesting to hear what others might say about this topic. I'm also interested in making an eye
glass case and would love to hear what others have to say that might have some experience with linings.
Edited by LNLeather
~Cheryl
pursue those...
edit......
Gah! I am racking my brain trying to think of ways to attach the microfiber cloth so that it isn't permanent. I want to have it attached so it isn't just lazily floating in the case. I was thinking velcro, but that is kind of tacky. A couple of snap buttons might work, but they'd be bulky. Im thinking now, that I may just line the one side with some suede, that way, no one will be rubbing any dirty microfiber which might scratch the lenses. The suede will at least protect the lenses when they are in the case, which is the purpose of the case, and I don't expect that the glasses will be moving around a ton inside of the case to cause the suede to scratch the lenses.
Thank you for finding that thread by the way, I didn't even think about needing to clean the cloth.
Hey, you are welcome...... I've been thinking about this and
I bet we are probably over thinking this... most cases I've seen have a liner
and
then you'd use a separate piece of soft microfiber to clean the glasses with.
I think when I make my case... I think I'll just put a bit of glue on the edges of a piece
of suede (or microfiber) cut to fit before assembly...
fyi - here's another link with a couple of patterns borrowed from an excellent leather-worker here.......
hope this helps :)
~Cheryl
pursue those...
and
hope this helps :)
Yeah, thats kinda what I was trying to get at in my last reply, definitely over-thinking it, haha (something I am notoriously guilty of).
I think I will do the same, and line half of the inside of the case with suede. Shouldn't be too difficult!
P.S - I purchased that Ev-R-Round circle cutter yesterday, Ill let you know how I like it!
I made a pouch out of microfiber cloth with a drawstring at the top and I just put my glasses in the pouch and slide them in the leather glasses case --- plus it gives me something to clean my glasses with...
~Tramp~
Experientia magistra stultorum --- (Experience is the teacher of fools)
