Contributing Member TwinOaks Posted November 25, 2014 Contributing Member Report Posted November 25, 2014 If I'm not mistaken, the circumference of a circle = 2 * Pi(3,14) * r ??? so...2*r = d, yes? and that's what I did......Pi * diameter But I like Brian's method....it's easier! So, I'll just use that one from now on. Here's the tutorial for round braid that I usually send people to: http://myriam.dakotabraiding.com/Tutorials/Leash/Leash.html Step by step picto-tutorial, and you can click each pic to get the instructions that go with the individual pictures. Also, look up Bernie46 on Youtube - he's a whip maker and shows how to bevel the lace with a homemade lace beveler..which will help the strands lay down correctly. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members Rocknrodeotack Posted November 26, 2014 Author Members Report Posted November 26, 2014 Thanks so much! Quote
Members wlg190861 Posted December 26, 2014 Members Report Posted December 26, 2014 To find the circumference of something its simply radius x pi(3.14 Quote
Northmount Posted December 26, 2014 Report Posted December 26, 2014 To find the circumference of something its simply radius x pi(3.14 You are half way there. C = Pi * D or C = Pi * 2 * r I think where estimates for strand widths for braiding are concerned, the 4.5 rule of thumb is likely a better estimate since the strands are not running parallel to the axis, but rather cross the axis on a diagonal. Tom Quote
Members bucksnort Posted December 31, 2014 Members Report Posted December 31, 2014 I think I'll use Brian's method & eat the pi. Buck Quote
Northmount Posted December 31, 2014 Report Posted December 31, 2014 I think I'll use Brian's method & eat the pi. Buck Where's the like button? Eating pi is the best! Tom Quote
Members Sovran81 Posted January 20, 2015 Members Report Posted January 20, 2015 Well that was hard to follow. No offense Brian I have great respect for you and your skills. I have learned a (probably same but) different formula that hasn't failed me yet. Circumference X 1.5 / number of strands = strand width. Easy peasy. I measure diameter and use an online calculator http://www.onlineconversion.com/circlesolve.htm to give me circumference(pi is for eating not figuring). From there its a simple math calculation. Any three numbers will give you the fourth. The circumference and 1.5 are standard to that job. Choose width or number of strands and you have the 3 you need to define the fourth. As a math calculation it works with any three as long as 1.5 is your constant. Quote
Members KnotHead Posted January 20, 2015 Members Report Posted January 20, 2015 I'm not offended. Whatever works for you. That's always been my thing. Brian... Well that was hard to follow. No offense Brian I have great respect for you and your skills. I have learned a (probably same but) different formula that hasn't failed me yet. Circumference X 1.5 / number of strands = strand width. Easy peasy. I measure diameter and use an online calculator http://www.onlineconversion.com/circlesolve.htm to give me circumference(pi is for eating not figuring). From there its a simple math calculation. Any three numbers will give you the fourth. The circumference and 1.5 are standard to that job. Choose width or number of strands and you have the 3 you need to define the fourth. As a math calculation it works with any three as long as 1.5 is your constant. Quote Best Regards, Brian Kidd
Members Sovran81 Posted January 20, 2015 Members Report Posted January 20, 2015 No mathematician here. Do the formulas work the same? As a dummy I try to use the easy way out unless extra work nets better results. Quote
Members KnotHead Posted January 20, 2015 Members Report Posted January 20, 2015 they'll work the same. only difference is the numbers. Quote Best Regards, Brian Kidd
