I did a search on this, but didn't find anything. My google-fu today may be weak.
I've started making some snap-on OWB pancake holsters. I'm using the approach I saw Mike/Katsass and a couple others detail here. Each half of the pancake is made from two 4/5 oz pieces of leather glued together, so it has a flesh side both on the outside of the holster and inside the pistol pocket. I'm really liking this approach. It makes a holster that's almost as stiff as Kydex.
After I glue the 4/5 sides together, but before I start assembling the holster, each flesh side gets a light coat of cold pressed Extra Virgin Olive Oil. Other than that, the inside liner is natural.
For people that use this "flesh on all sides" approach, do you apply any treatment to the flesh side liner in the pistol pocket to improve durability, etc.?
Thanks
I believe you meant grain side exposed inside and out. I use neatsfoot oil inside and out after molding and drying just prior to finishing.
OOP's. Thanks for the correction on the grain side.
Do you dip the holster in neatsfoot oil or just rub it into the surface with a wool dauber/soft cloth?
I give it a quick dip in warmed oil then let it sit for a day before finishing.
Put that piece of leather in the sunshine and give it a beautiful tan. Seriously.
The last one I did like that, . . . I dip dyed the two outside layers in black before assembly, . . . made one purty, purty holster.
My only "mistake" was the leather I used was just a tad on the heavy side, . . . actually wound up with a holster that could be used as a weapon, . . . it is so stiff and hard.
But it shore is purty.
And, . . . yes, . . . as mentioned earlier, . . . a good coat of neetsfoot oil will do good for both the holster and the gun inside it.
I also do not put any finish on the insides of those holsters.
May God bless,
Dwight
www.dwightsgunleather.com
During the assembly stages of 2-layer holsters I treat them the same as single-layer. Form normally. Dye normally, When ready for finishing I like a modest application of neatsfoot oil to all exposed surfaces (interior and exterior) which can be done with a brush or rag. Then edges are burnished. Then sealant is applied. Then final finishes are applied. The key to all of it is allowing plenty of time between each step in the process. Dyes require 12 to 24 hours to set up. Neatsfoot oil requires 12 to 24 hours to penetrate and "settle in" to the leather. Acrylic sealants require several hours to set up (4 to 12, depending on temperatures and humidity, specific sealant used, etc). Final finishes also vary, but most will require 12 hours to cure out (assuming warm dry environment).
Regardless of specific methods and products, trying to rush the process is probably the easiest mistake to make. All of these chemicals and compounds we are using can interact with each other in unpredictable ways, especially when we haven't allowed sufficient time for everything to set up properly.
Lobo Gun Leather
serious equipment for serious business, since 1972
www.lobogunleather.com
Thanks all.
I guess I was thinking that over time residue oil and solvents left on the pistol from cleaning would get absorbed by the liner and could damage the leather. Looks like I'm over thinking it.
Thanks for the giggles, Lobo, . . . sometimes something is said that takes us back to our "voice of experience" lessons. Your last line above is a sure winner in that department.
May God bless,
Dwight
That's the hard part for me sometimes, just leave it alone 'til tomorrow.
Keep on Chooglin'
Check out my YouTube Channel, comment and subscribe for updates
https://www.youtube.com/channel/UCOM3hbruUKHov9kquIxXKlA
