Rooster the idea is not to pancake them as you put it initialy. You want to put the holster together with the tension screw so that there is not a lot of pressure on the rubber initialy. THis leaves you a range in which you can tighten the tension screw down to give desired tension. Some people make so initialy the rubber is compressed about halfway. This leaves you adjustment either way if you want to lighten the tension or tighten the tension.
Yep. As others have said, you can use chicago screw posts as well. They give a more 'finished' look. I've used them as well, whichever fits the application.
"Courage brother, do not stumble, though thy path be dark as night: There is a star to guide the humble, trust in God, and do the right. Let the road be dark and dreary and its end far out of sight. Face it bravely, strong or weary. Trust God, and do the right." - General Norman Schwarzkopf
