Members frank207 Posted November 11, 2008 Members Report Posted November 11, 2008 I have read recently that you should clean the leather with 'oxalic acid crystals' before dyeing. Is there any other homemade solution that can be used thats just as affective? Thanks Frank Quote
ferret Posted November 11, 2008 Report Posted November 11, 2008 I've never tried oxalic acid but I've had good results from lemon juice Quote
Contributing Member UKRay Posted November 11, 2008 Contributing Member Report Posted November 11, 2008 Interesting question as I have never routinely cleaned my leather with anything before dyeing - It hasn't needed it. Okay, occasionally there might be a few waxy spots that respond to a drop of methylated spirit but these are few and far between. Have I misunderstood the problem? Quote
Members frank207 Posted November 11, 2008 Author Members Report Posted November 11, 2008 Ferret, Do you use the lemon juice straight or do you mix it with something? UKRay, No you did not mis-understand the problem. The strap for my First belt is a little spotty, maybe from handling it. Thanks for the input Frank Quote
yaklady Posted November 12, 2008 Report Posted November 12, 2008 Ferret,Do you use the lemon juice straight or do you mix it with something? UKRay, No you did not mis-understand the problem. The strap for my First belt is a little spotty, maybe from handling it. Thanks for the input Frank Use the lemon juice straight. Just put some in a little dish, and sponge it on. Wipe it with a clean sponge when you're done. You'll be surprised at how your sponge looks when you're done with it. Kathy Quote
Members MikeCahill Posted January 14, 2011 Members Report Posted January 14, 2011 Use the lemon juice straight. Just put some in a little dish, and sponge it on. Wipe it with a clean sponge when you're done. You'll be surprised at how your sponge looks when you're done with it. Kathy doesn't that make it sticky Quote
Contributing Member Ferg Posted January 14, 2011 Contributing Member Report Posted January 14, 2011 doesn't that make it sticky Lemon juice, like most citric juices are natural bleaching agents. Vinegar is a stronger version and will clean absolutely anything but I wouldn't use it on leather, it may smell a little strange for awhile A number of folks have been a little afraid to use the Oxalic Acid crystals, dissolved in water, by the way. I have a plastic container with the Oxalic solution, I notice no smell or gas off and it doesn't burn my hands, I normally wear thin rubber gloves when handling it. I rinse the leather with clear water after the application. I can assure you, there is a lot of junk on that leather you don't see unless you are one of the few folks that have no "oil" in your skin. Packaging residue is another problem some times. Just clean it, you won't need to worry about it then ferg Quote
Members Mojo66 Posted February 13, 2011 Members Report Posted February 13, 2011 Oxalic acid's also found in rhubarb, rubbing leather with a stick of rhubarb seems an odd thing to do though. Quote
Tree Reaper Posted February 13, 2011 Report Posted February 13, 2011 What is the proper way to clean the leather without messing up the tooling? Kevin. Quote
Members Lurker Posted February 14, 2011 Members Report Posted February 14, 2011 I don't really need to clean the leather in most cases unless I have a greasy spot or need to remove a finish to re-dye another colour. When that happens I use a bit of cheapo nail polish remover on a sponge or cotton ball. Works great for me and it's easy to find. Quote
