3-4oz. leather worked okay for me. I had to play with it at first but it ended up working.
Thank you for the pattern!
Thanks Tom......appreciate you using your skills to provide some help to all of us.
Greetings from Central Texas!
The Grain Side Up blog
#TheGrainSideUp
Me likey. That's just the thing for a point of purchase at fairs and festivals. Most everybody has a cell phone and keys. I've taken the year off from setting up a vendors table but I've got ideas for next year and that'll fit right in.
Keep on Chooglin'
Check out my YouTube Channel, comment and subscribe for updates
https://www.youtube.com/channel/UCOM3hbruUKHov9kquIxXKlA
  • 2 weeks later...
All of the scraps I have on hand right now are from 7 oz or higher leather. Any ideas on how this pattern could be modified to accommodate a thicker leather? Regardless, I'm going to try it even though it will undoubtedly be too stiff. It's too cool not to!
  • 2 weeks later...
Krisbee, for heavy leather you could probably make the two end cuts a little longer, plus a little creative skiving to induce a little more bend in the folded arc.
If the normal one is ___|-----------|___ then for heavy maybe ______|----------|______ y'know?
I don't suffer from insanity, I enjoy every minute!
www.rogueleather.com
Thanks for the pattern.
5-6oz Crazy Hose pull up.
11403354_1035800346430258_1155560586354611751882_1035800336430259_81647487750923
  • 1 month later...
  • 3 weeks later...
  • 2 weeks later...
Thanks Tom!
  • 10 months later...
As many others have said, . . . "Thanks", . . . this WILL be made at least once.
May God bless,
Dwight
www.dwightsgunleather.com
  • 2 years later...
  On 3/10/2015 at 3:32 PM, tboyce said:
Я видел это на Pinterest, и это выглядело как вещь для всего лома, который я всегда собираю.
Это самый полезный брелок, с которым я когда-либо сталкивался, супер легко и быстро выбить.
Размер отпечатка 8-1 / 2х11
keyring.pdf
Expand
Дякую
Still cool!
  • 2 weeks later...
Thanks for the pattern, it will be interesting trying it with different leathers to see how they work for the application to support the phone. It will be a good learning exercise for personal use.
  • 1 month later...
  • 3 months later...
You da man TOM!
